Honda Bonnet (Hood) Doesnt pop up but cable ok
Old Sep 9, 2013 | 08:45 AM
Keith Coles's Avatar
Default Honda Bonnet (Hood) Doesnt pop up but cable ok
Hi,
First time poster.
I am hoping you can help. I have a problem with my bonnet. When I pull the release the bonnet doesn't pop up. The catch is working as I can manually lift the bonnet if the lever is held in a pulled position but the initial pop (Springing up) doesn't happen. The bonnet is secure while the lever isn't pulled so the lever / cable is functioning..
Bit of a pain as it takes 2 people to open the bonnet (One to pull the lever and one at the front to lift the bonnet. This is obviously a pain as I cant open it on my own.
Thanks in advance for any ideas / solution.
Thanks,
Keith.
Old Sep 9, 2013 | 10:20 AM
Default Re: Honda Bonnet (Hood) Doesnt pop up but cable ok
Forgot to mention 2001 Accord model.
Thanks.
Old Sep 9, 2013 | 11:03 AM
MAD_MIKE's Avatar
MM Gruppe B
Clean the latch and regrease.
Old Sep 9, 2013 | 11:56 PM
Thanks I will give it a try.
I must admit it was a bit gunky but did not think a bit of gunk would stop something strong enough to lift a bonnet?
I will post back with the result.
Old Sep 10, 2013 | 08:57 AM
Got to the bottom of it.
On taking the latch off (With the intention to just clean it) I found that the large spring within the mechanism had rusted and the bottom hook had snapped off. After some reforming of the bottom loop of the spring into a new hook I managed to reconnect the spring between the two connecting points.
Bonnet now pops up as it should.
Thanks,
Keith.
user 98292739
Sep 5, 2006 08:12 AM
brcivic411
Mar 4, 2006 02:51 PM
hondacivic_si
Jul 12, 2004 09:07 PM
akaEsCo01
May 31, 2004 02:55 PM
Eggman
Jun 10, 2003 10:09 AM
