chips that add horsepower and mpg? good or bad for the car??
Old Sep 9, 2013 | 06:32 AM
CR4ON2IC0's Avatar
Default chips that add horsepower and mpg? good or bad for the car??
I basicly wanna know if any of these many chips are good for tuning or do you really get more power and better mpg? and if they do are they bad at all for your engine or do they break your engine or what ever. only thing on my 95 honda civic is exaust and K&N air filter..ha i know no power just want it to get more gas mileage mostly but if it add power thats a good bonus and if its ok for the engine i'm gunna get one and if you can recommend any that someone has tried thank you
here are some i looked at. $69 Honda CIVIC Chip - Gain 60 Horsepower Instantly‎
www.gfchips.com/‎ Honda Civic Chip - Gain 75HP+TQ and MPG Instantly‎
www.autochipsdirect.com/‎ $55.99 Civic Power Chip - More HP, Better MPG‎
Old Sep 9, 2013 | 06:50 AM
allshowfxt's Avatar
Default Re: chips that add horsepower and mpg? good or bad for the car??
Don't do it they are junk look at the TQ/HP gains it promises. There's no way that's happening. The chips are not made for your car at your altitude more likely then not it won't be much better if at all. Try looking up hypermile stuff on the Internet. The first place to start it doesn't cost you money (the reason you want better gas milage) if you just work on your driving.
Old Sep 9, 2013 | 08:03 AM
HondaPartsHero's Avatar
Technical Hero
Many have tried even after advice not to do it. Will not add power, will probably lose power. Will not add mileage and will probably cause worse mileage.
Old Sep 9, 2013 | 08:11 AM
grumblemarc's Avatar
The Grumpiest
OP will do it anyway. If you think $70 can get you 60-75hp go right ahead and install that thing like yesterday.
Old Sep 9, 2013 | 09:03 AM
CR4ON2IC0's Avatar
ughh..yeah figures.. anyone ever try it though? that can give some advice? cuz all thoughs answers dont sound for sure. but thanks for driving tips ha
Old Sep 9, 2013 | 09:26 AM
doood's Avatar
been there done that
it's a sure thing the only advantage is a lighter wallet
Old Sep 9, 2013 | 10:38 AM
The Grumpiest
Number one, can your car even use the chip? Probably not. Number 2, if these pieces of **** actually worked don't you think everyone would be using them? And that they'd be more expensive?
Go ahead, you know you're going to get it anyway. Why don't you report back and tell us.
Old Sep 9, 2013 | 06:29 PM
CR4ON2IC0's Avatar
ha nah idk gunna do more research first i guess just figured someone here would of tried it
Old Sep 9, 2013 | 06:52 PM
mattbatson's Avatar
I think what people are trying to tell you, is that nobody here is stupid enough to pay money for that crap.
Those chips are rip off's/scams and only a complete idiot would buy one.
THAT is the reason nobody on here has bought one.
Old Sep 9, 2013 | 07:07 PM
doood's Avatar
have you ever heard of snake oil?
Old Sep 9, 2013 | 07:10 PM
The Grumpiest
But I bet OP will get one. Just waiting for ONE person to say that they work.
Old Sep 9, 2013 | 11:11 PM
jdmjunkieXL's Avatar
Oh man those work op you should get one
Old Sep 12, 2013 | 06:44 PM
swordofdoom's Avatar
Send me a $150 bucks and I'll send u a P28 ECU chipped for more crap.
Old Sep 12, 2013 | 06:57 PM
Themonk's Avatar
I am one of those idiots who has purchased one of those chips and can tell you they are not very safe for your vehicle. My motor was knocking something crazy after I installed the chip even with higher octane gas. Chip removed ran much better , I sold it and put money towards new tires much happier.
Old Sep 13, 2013 | 01:30 PM
h_wells3000's Avatar
those ads that say ADD 90 HP and 15 MPG are specifically designed to take advantage of people. although there is a possibility one may be legit (certainly not for anything remotely close to the above claims). 99% of the time They're a waste of $$ This question has been resolved thousands of times. Do a quick search before opening a discussion, but good luck with the car and Read read read, and save yourself $$$$
Old Sep 17, 2013 | 08:19 AM
CR4ON2IC0's Avatar
ok thanks alot guys will not be buying the chip. anyone know of a good way to get more mpg's out of the little honda? or maybe i'll look for a different thread thanks though and if anyone wants to close this thread then go for it i'm not sure how to or if i can.
Old Sep 17, 2013 | 10:07 AM
Themonk's Avatar
i use a warm air intake, i simply removed all the intake plumbing to pull cool air from outside so that now my cars pulls air from the engine bay. i have also added an airdam and run my tires at 42 psi front and rear. i usually achive high 40's to mid 50's on the highway and mid thirties on the low end in the city. this is also using some fancy driving.
Old Sep 18, 2013 | 08:44 PM
tobi7's Avatar
the chip will make the firing either sooner or later. it might add a little bit of hp but it will also damage your engine
Old Sep 18, 2013 | 08:47 PM
tobi7's Avatar
just curious about the warm air intake, i dont know anything about it. how much better is it? modifying for it doesnt sound hard at all.
Old Sep 18, 2013 | 09:11 PM
raverx3m's Avatar
you need the chip
you need the electric turbocharger
a hood scoop
and the fuel line magnet to get better gas mileage
Old Sep 19, 2013 | 10:16 AM
Themonk's Avatar
i use a scan gauge to monitor my gains along with several trials. the warm air modification gains me on avg 3 mpg, more so during cold temps as it aids in getting the motor up to temp.
Old Sep 19, 2013 | 02:23 PM
m4xwellmurd3r's Avatar
I was trying to figure out why a warm air intake would net more mpg then I realized why
Warm air is less dense, while not good for power, is good for milage since the ecu trims out fuel to compensate, correct?
Old Sep 19, 2013 | 11:41 PM
MAD_MIKE's Avatar
MM Gruppe B
Hot air atomizes fuel better, which burns it more efficiently. And pumping losses are less since the throttle needs to be opened further to allow more less dense air into the engine. So there is a more complete burn, and less power lost in pumping.
Gargoyle33
Honda Civic (2001 - 2005)
Dec 23, 2009 09:48 PM
ken9
Apr 17, 2009 12:24 PM
Lost_clearance
Jul 20, 2007 01:50 PM
bluedelsol
Jul 7, 2003 05:53 PM
