Civic 1998 problems
Old Sep 8, 2013 | 09:10 PM
Soup Slayer's Avatar
Icon3 Civic 1998 problems
Greetings once again ya'll.
So I'm having a few problems with my 1998 Honda civic Automatic with 165k Miles.
Recently My car was throwing codes for:
P0501 VSS
P0135 o2 Sensor
P0325 Knock Sensor
So I replaced all of these parts and the codes keep coming back. All the parts where purchased from Autozone and have warrenty and I don't think that is the problem. Recently the cars lights (In dash, and outside) have been flickering and when the car is at idle, it sounds like a child saying "room room" very slowly nonstop.... (Hope you know what i mean)... Anyways the idle sounds like it's off a tad, the CEL is constantly on and the codes listed previously won't go away.
I did a Ghetto alternator test, "Unplugg the ground while the car is on". and the car struggled to stay on and the lights wen't nutts... Possibly indicating that the alternator is going bad... I'm wondering though if it could be some of the fuses or possibly some of the ground running through the car. Any ideas would be awesome. I will be taking it to autozone to test the alternator.
Thanks in advance.
Old Sep 8, 2013 | 09:24 PM
jbpnoman's Avatar
Default Re: Civic 1998 problems
Check fuse 15 in your under-dash fuse box. Your symptoms almost perfectly mimic the fuse 15 TSB.
Old Sep 9, 2013 | 09:14 AM
I checked and it was missing the 15 fuse. Popped one in and it seems like the VSS ruff idle etc is solved... CEL is still lit and the knock/o2 codes won't go away.
Old Sep 9, 2013 | 05:26 PM
Bump
Old Sep 9, 2013 | 06:35 PM
jbpnoman's Avatar
Reset your ECU, see if the codes come back.
Old Sep 10, 2013 | 05:46 PM
How do I do this?
Old Sep 11, 2013 | 05:03 AM
Chriser0's Avatar
Pull back up fuse under hood for 15- 20 sec. I believe its a 7.5 amp. Make sure if you have the factory radio you have the code for it or you wont have any tunes any more.
Old Sep 11, 2013 | 01:36 PM
ElectronBlue00's Avatar
Originally Posted by Soup Slayer
How do I do this?
Easiest way is to just disconnect the battery cables for 15-20 seconds.
PsXtreme
Mar 15, 2016 12:43 PM
xTomei
23
Aug 25, 2010 08:00 PM
Lewis7789
Jun 12, 2007 02:22 PM
ITR.#1446
Mar 23, 2007 06:13 PM
TheCopierWrench
Oct 19, 2004 06:21 PM
