Need help resolving check engine light 4 - Crank position sensor
Old Sep 8, 2013 | 06:59 PM
MrDomino's Avatar
Default Need help resolving check engine light 4 - Crank position sensor
First off, the crank position sensor, CKP, is the one inside the distributor, not the crank fluctuation sensor that's on a toothed wheel near the crankshaft.
I've checked all three sensors at the distributor and am seeing around 350 ohms. CHECK
I've checked all three sensors at the ECU and am seeing 350 ohms. CHECK
I've checked all three sensors at the ECU and do not see any shorts to ground. CHECK
I'm guessing that would make it an ECU issue. Is there any way to actually fix the issue with the ECU instead of scrapping it and buying a new one? I'm guessing something in the circuit blew up so if I can just replace a resistor or capacitor and fix the issue then I'd rather do that than spend $200 on a new chipped ECU.
naderesb
Nov 20, 2022 02:36 AM
xXCarfreakXx
Aug 9, 2008 11:54 AM
SwappedLSHatch
Apr 13, 2006 01:33 PM
Pony_Fed95
Jan 17, 2006 01:51 PM
ahc'monracing
Sep 24, 2002 01:26 PM
