Moving Garage cleanup.... MISC honda parts ... check inside..
Hi there folk.. im moving in 2 months and i need to sell couple of thing or 5 everything... i have been gathering parts for over 5 years and i don't want to bring everything with me . im willing to give out good deal. i have paid for those parts at first so they wont be free ...
any reasonable offer will be accepted.
I took couple of quick pics but if you need any close up i will do it.
i just didnt want to pull every single parts for picture . i have too much.
quick list, i might forget parts but try to do my best.
dc5 ebrake cable
dc2 ebrake cable
dc2 5lugs conversion 5x114.3
dc2 4lugs conversion 4x114.3
h22 crower I rod with wiseco pistons 87mm
h23 pauter rod je pistons 87mm
k24 crank puley
k20 crank puley
wilwood caliper dynalite
h22 type-s camshaft
h22 type-s double spring retainer
h22 jdm camshaft
h22 crower stage 2 camshaft
h22 cylinder head
f20b cylinder head
f20b intake manifold
h22 intake manifold
k24a2 cylinder head
k24a4 cylinder head
ek9 axles 32mm
dc2 axles 36mm
dc5 axles 36mm
big brake project me 300mm X 30mm with euroR calipers project mu pads fit any 5 lugs honda
ek9 recaro rails
dc2 recaro rails
dc2 front calipers
s2000 calipers
s2000 front hubs
h22 valve cover
k24 oil pump
k20 oil pump
k24 oil pan
k20 oil pan
k24 rods and pistons
k24 block
k20 block
h22 block
f20b block
h22 crank 55mm knif edge balanced
k24 water pump housing
k20 water pump housing
k20 flywheel
h22 flywheel
h22 alternator
h22 starter
prelude tailight
ek9 tailight
ek4 tailight
dc2 tailight
k24a2 crank
k24a2 intake manifold
k20z1 intake manifold
k20 dip stick
k24 dip stick
dc2 front control arms
dc2 rear control arms
ek9 front control arms
ek9 rear control arms
ill try to update more later on.
dc5 ebrake cable
dc2 ebrake cable
k24 crank puley
k20 crank puley
h22 type-s camshaft
h22 jdm camshaft
h22 cylinder head
f20b cylinder head
h22 intake manifold
k24a2 cylinder head
k24a4 cylinder head
ek9 axles 32mm
dc2 axles 36mm
dc5 axles 36mm
ek9 recaro rails
dc2 recaro rails
dc2 front calipers
s2000 calipers
s2000 front hubs
h22 valve cover
k24 oil pump
k20 oil pump
k24 oil pan
k20 oil pan
k24 block
k20 block
h22 block
f20b block
k20 flywheel
h22 flywheel
h22 alternator
h22 starter
prelude tailight
ek9 tailight
ek4 tailight
dc2 tailight
k24a2 crank
k20 dip stick
k24 dip stick
wtf...
man i thought i was a jedi parts huslter. even in my prime i didn't hoard that much stuff.
I know how much PITA it can be to sort/organize & the patience needed hold on it stuff.
bump for you sir
bump for you sir
i know how you feel...
i cant just not do it .... i gather stuff when it comes to cars...
but im moving just i need to sell stuff out.
Interested in the following parts but because you seem to be in Canada, shipping is going to be a pain:
h22 type-s camshaft
ek9 axles 32mm
For the k20 crank puley, do u have the PRB or PRC version?
h22 type-s camshaft
ek9 axles 32mm
And on the next episode of Honda Hoarders, we present p1mmiz321. Why did he think he needed over 50 Integra throttle cables? Tune in to find out!
For serious, though: Who do you use for shipping the large heavy stuff from Canada -> USA? I might need to do this myself. Thx.
Canada post for everything below 30Kilos. big box 25*25*25 inch
if you have to ship freight 1 meter scare 250 pounds with day and ross in very affordable.
i have ship engine this way to usa easily.
