02 Accord Trans bump
Old Sep 8, 2013 | 06:10 AM
02NCAccord's Avatar
Default 02 Accord Trans bump
I had another thread started about some cooling issues and it seems they have all been worked out.
I did have another thing started to happen last night. when I put it into drive (D4) it engages then gives a second jerk. all gears and shifts feel fine once it gets going. its just that initial shift into drive. planning on changing the trans fluid today, its looks pretty worn out. its clear but almost brown and seems kind of thin. aside from the worst case (being a trans rebuild) what can I do to diagnose whats going on? maybe a shift/ vacuum modulator or something like that? 188K miles on it.
thanks for the help.
Old Sep 10, 2013 | 04:24 PM
Lost Again's Avatar
Default Re: 02 Accord Trans bump
Check the mounts. Have someone you trust put the car in R and then to D4...apply slight throttle and see if there is movement of the engine/trans.
bigd85yota
Feb 10, 2020 11:07 AM
Gizler00
Mar 25, 2009 07:41 AM
NMef9
Dec 26, 2006 07:00 AM
Rasago
May 3, 2006 01:00 PM
