couple questions about oil
1.) What exactly does cooler oil do for you?
2.) I've heard that Thermo-wrapping your header helps to keep oil temp down, how about that Spoon Heat Barrier Tape?
3.) Does anyone have a link to the oil filter test? I saw it on here about a year ago; and I know I can do a search, but I figure since I'm asking other questions about oil, I'll throw it in.
4.) Has anyone tried that magnet that goes over your oil filter, it's supposed to trap metal to the outside of the filter?
5.) I'm doing an oil change this weekend, should I switch to 10W-30 since it'll be winter? (Right now I'm using 5W-30. The manual says 5W-30 can be used if the temp doesn't go below 20F and here the lowest temp is in the low 30's but that won't be till December and I probably won't even drive when it's that cold)
Now for those that don't understand english, I'll repeat in stunna talk!
1.) Yo what does a mad phat oil cooler do yo?
2.) Yo does that Spoon Heat Barrier Tape work, it's JDM so it gotta add like 20 HP right dog?
3.) Can someone hook a brotha up wit a link to the test on them oil feezies?
4.) Yo that magnet for your filter son, how dat be workin yo?
5.) If I'm doin an oil change this wizzie, should I switch to some 10W-30?
[Modified by cipherpimp, 10:38 PM 10/25/2002]
[Modified by cipherpimp, 10:42 PM 10/25/2002]
[Modified by cipherpimp, 10:43 PM 10/25/2002]
