what size t type tool is needed to replace window regulator?
Old Sep 7, 2013 | 02:01 PM
datant69's Avatar
Default what size t type tool is needed to replace window regulator?
Drivers side is stuck all the way up, passenger side jumps off track. I need to know tool size for the 3 bolts holding the actual motor to the frame. Any tricks or watch out for whatever maybe ahead of me tomorrow when I tackle it. I also want to know how can I loosen the window and take it out if its all the way up. Degree of difficulty would be good also. I'm handy and think I can tackle it but just wanted to ask some gear heads for something they can do in salt less time then me tomorrow.
Also my pass window jumps off track, its done it twice and I'm trying to fix it right. I used liquid wrench lube to help it up and down but didn't completely cover all of it. It'll work fine once its on there for a little bit but I need it to work right without me having to keep on dropping my door panel.
Thanks in advance
Old Sep 7, 2013 | 02:15 PM
grumblemarc's Avatar
The Grumpiest
Default Re: what size t type tool is needed to replace window regulator?
RIGHT NOW.
GO and search for the field service manual for your Civic.
In it - step by step instructions for this simple stuff.
eG6haTchY
Mar 21, 2009 03:53 PM
90lsteg
Jul 28, 2008 10:21 AM
migizzel
Aug 15, 2005 06:14 PM
mntdewred
Aug 17, 2003 07:26 PM
