Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
running too lean=bad??
Old Sep 5, 2013 | 06:28 PM
immajackuup's Avatar
Default running too lean=bad??
I'm running at 13.6-13.9 at woot. is that bad??
Old Sep 5, 2013 | 06:43 PM
doood's Avatar
been there done that
Default Re: running too lean=bad??
is it tuned?
Old Sep 5, 2013 | 07:14 PM
Originally Posted by doood
is it tuned?
yes it was tuned with the previous afe intake but now I have rick spec intake 3.5in.
car drive and pull hard without any problem.
Old Sep 5, 2013 | 07:45 PM
DaveSi677's Avatar
what kind of a cal are you using?
DaveSi677's Avatar
its always best to run a little richer but too lean isn't good
Old Sep 5, 2013 | 07:54 PM
using someone else cal which was tune perfect at 13.3 steady woot till I install new 3.5in intake.
Old Sep 5, 2013 | 07:57 PM
doood's Avatar
what other mods do you have?
it's not dangerously lean but can stand to be richened up a bit. you're bringing in more air now with a bigger, freer flowing intake. using someone else's cal is a no-no.
Old Sep 5, 2013 | 08:01 PM
rick spec intake
rv6 catless dp
3inch UR cat-back
rbc intake manifold
zdx tb
The cal i'm using is the same guy that tuned my a/f perfect which he has same spec except intake. is a dyno tune cal.
Old Sep 5, 2013 | 08:07 PM
doood's Avatar
doesnt matter. it's not the same anymore. even when it was, every engine is different.
Old Sep 5, 2013 | 08:10 PM
what you think about etune?
Old Sep 5, 2013 | 08:18 PM
doood's Avatar
i have access to a great tuner. i know people in the 8th civic community love to ride a certain etuner's nuts. if that's all you can get then go for it.
Old Sep 6, 2013 | 03:46 AM
That's what I want to hear lol reason why I use someone else real dyno proven cal that is closer to me then adjust a/f.
Old Sep 6, 2013 | 10:21 AM
DaveSi677's Avatar
cause it was dyno tuned doesn't mean anything!
etune is a good way to go.
If you want the best etuner VitViper is your man.
Also never use someone else's tune... you don't have the same exact engine!
Jo$e L@go
13
Jan 20, 2009 11:30 PM
zeroz
Apr 16, 2005 05:16 PM
JDMvision
Jul 25, 2004 07:45 PM
sharkey65a
Jan 9, 2003 07:37 AM
