Dx si conversion issues
Old Sep 4, 2013 | 11:27 AM
hypeonline's Avatar
Default Dx si conversion issues
I just for the most part completed my swap now, but the motors not responding to throttle input, and its like its running rough, im not certain what it is ill get a vid up of it running soon, its throwing a cel not sure on the code but ill figure out soon
Old Sep 4, 2013 | 11:49 AM
crx_si-r's Avatar
Default Re: Dx si conversion issues
Did you swap the 2 outside wires on the tps plug?
Old Sep 4, 2013 | 12:04 PM
hypeonline's Avatar
Yea I switched the tps wires, I forgot to mention it surges also, im running obd1 injectors, could it be tge duzzy wired wrong?
Old Sep 6, 2013 | 09:40 AM
Dr.ofCARS's Avatar
the impedance is different between obd1 and obd0 injectors. are you runnning a pm6 ecu and did you install the injector resistor box? if so your gunna need to get some obd0 injectors to start.
Old Sep 6, 2013 | 09:49 AM
24TEN's Avatar
PHANTOM MENACE
OBD1 injectors should be fine to use as long as they are wired properly (OP please clarify if you have done this). The very first thing that should be done is to obtain the code. That's usually the car's way of telling you something is wrong
Old Sep 6, 2013 | 10:49 AM
Freemananana's Avatar
Originally Posted by hypeonline
its throwing a cel
Definitely get the code. It's real easy on OBD0 cars. Just look at the ECU.
Usual idle issues include TPS, FICV, vacuum leak, IACV, EAVC, MAP sensor or something generally wired wrong.
Get the code and go from there. That's always the place to start.
Efmysedan
11
Apr 25, 2019 03:24 PM
nickeynick
Jun 29, 2009 08:52 AM
nucivowner
Mar 11, 2005 11:33 AM
civicefdx
Oct 24, 2004 03:25 PM
ruby civic II
May 27, 2004 06:09 PM
