wiring help
so i need to install some sort of ecu cut out. im looking to tie into the ingition to allow the car to simulate normal start up but not allow the injectors to deliver fuel. is there any way to find a full wiring schematic for 98 integras? ive tried some mild searching but no luck. if you guys could point me in the right search driections that would be greatly appericated!! i need to stop my car from getting stolen. its been stolen twice in the last 2 months!! luckley ive recovered it both times with the help of the local police department. they stole my wheels twice and everything in my car. thanks in advance for amy help!
You did not search enough, a "kill switch" on the ground lead, [black] for the PGM-FI Main Relay will prevent fuel injectors from working, but engine will still crank.
You could also put the "kill switch" on just the power to the injectors so only the injectors are effected, instead of everything controlled by the PGM-FI Main Relay. 94
