wiring help
Old Sep 3, 2013 | 08:49 PM
minipratt89's Avatar
Default wiring help
so i need to install some sort of ecu cut out. im looking to tie into the ingition to allow the car to simulate normal start up but not allow the injectors to deliver fuel. is there any way to find a full wiring schematic for 98 integras? ive tried some mild searching but no luck. if you guys could point me in the right search driections that would be greatly appericated!! i need to stop my car from getting stolen. its been stolen twice in the last 2 months!! luckley ive recovered it both times with the help of the local police department. they stole my wheels twice and everything in my car. thanks in advance for amy help!
Old Sep 4, 2013 | 06:39 AM
fcm's Avatar
fcm
Old Fart
Default Re: wiring help
You did not search enough, a "kill switch" on the ground lead, [black] for the PGM-FI Main Relay will prevent fuel injectors from working, but engine will still crank.
You could also put the "kill switch" on just the power to the injectors so only the injectors are effected, instead of everything controlled by the PGM-FI Main Relay. 94
motordog
Honda CR-V & Element
11
Dec 21, 2023 10:37 AM
xsianthracite
Acura TL, RL & ZDX
Dec 27, 2014 05:15 PM
integrawillie
Apr 20, 2012 06:01 AM
"N8"
11
May 14, 2011 08:53 AM
N'viouzEF9
Mar 4, 2011 09:16 AM
