Recommend Pa. Rebuilder ?
PM HondaBull on here
https://honda-tech.com/forums/members/honda-bull-999407884/
Great dude and very knowledgeable tranny builder.
I did consider shipping it to you but the shipping charges would probably be too much.
I just finished doing it myself, following the instructions in this forum.
The only thing I might have screwed up is I might have put the spring washer
Under the mainshaft in upside down.
I was about to put it back in the car but I'm trying to decide if I should.
Anyone here ever make that same mistake ?
What kind of symptoms can I look forward to ?
Take it back apart and check, the spring washer needs to be in the correct orientation or the shim clearance and gear mesh will be off.
Shipping from/to PA is pretty cheap.
Definitely check that spring washer, Jack, before you put it back in the car.
I still can't believe there's a Type-R swapped Mini in Pennsylvania. LOL
Torque solution
Apr 2, 2010 03:40 PM
thapimpfromchi
Jun 19, 2008 01:18 PM
