Code 43, Emission failed need urgent Help
Old Sep 2, 2013 | 08:06 PM
vedha's Avatar
Icon2 Code 43, Emission failed need urgent Help
I have 1990 Honda accord ex, it failed the inspection. The inspector told the car is running
rich and showed the blinking light which produced code 43. I then replaced O2 sensor,
fuel pressure regulator, fuel filter. Spark plugs, distributor and rotter. Also cleaned EGR shift valve. None of it produced the any result. I don't no where to look. I really need help.
I checked the fuel Injectors connectors and its resistance which was 2.5 Ohms and all is fine. Also I did sound check by removing the connectors one at a time and all sounded the same when engine is running.
Symptoms of my car now stands at low idling (500 to 600 ) when parked or N.
Automatic Shifting the gear at 3000 to 3500 RPM. CEL comes when gas peddle
is hold at 3000 RPM. I have cleared the code many times and still coming with
code 43. My Honda has 220K miles.
Old Sep 2, 2013 | 10:00 PM
holmesnmanny's Avatar
Default Re: Code 43, Emission failed need urgent Help
this tends to be an exhaust leak somewhere from the exhaust manifold to the oxygen sensor...Just seafoam your car and look for white smoking leaking out of the exhaust in that area.
Old Sep 10, 2013 | 04:28 PM
vedha's Avatar
I checked for exhaust leak in the front pipe by blocking tail pipe.Yes there was leak more on one side the other. I don't no whether it will solve code 43 remains to be seen in couple of days while I shop around for gasket. I really appropriate your help Homesnmanny.
DeCoY
Feb 9, 2018 10:27 AM
vedha
Sep 30, 2013 02:10 PM
vedha
Sep 15, 2013 11:12 PM
FTW_Accord94
Apr 9, 2009 08:39 AM
Cole D
Jul 10, 2003 08:25 PM
