1990 honda civic hatchback si throwing code 13 (Barometric Sensor) help
Old Sep 2, 2013 | 06:27 PM
wing.jai's Avatar
Default 1990 honda civic hatchback si throwing code 13 (Barometric Sensor) help
Hello,
Have anyone dealt with code 13 (Barometric Sensor) on their civic hatchback si? I am having that problem right now. how do you fix it? The car is a 5 speed, i been doing some search on google and everyone that dealt with this have to change their ecu. can any of the admin/technician on here confirm this?
Thanks.
Old Sep 2, 2013 | 06:40 PM
crx_si-r's Avatar
Default Re: 1990 honda civic hatchback si throwing code 13 (Barometric Sensor) help
Your baro sensor is located on passenger side kick panel. Just behind the trim. It's a 3 wire sensor bolted down with 2 10mm bolts. Newer cars have them built into the ecu
Old Sep 2, 2013 | 07:11 PM
wing.jai's Avatar
oh cool. ill take look at it. do you know how much is cost for a new sensor?
Old Sep 2, 2013 | 09:33 PM
wing.jai's Avatar
ttt
Old Sep 3, 2013 | 05:57 PM
wing.jai's Avatar
ttt
Old Sep 7, 2013 | 04:16 PM
wing.jai's Avatar
ttt
Old Dec 9, 2013 | 09:14 PM
wing.jai's Avatar
problem was fix. found out timing belt strip. skip 7th teeth! had to send out head to machine shop to get the head resurface and change out 4 bent valve.
Old Dec 10, 2013 | 02:50 AM
Freemananana's Avatar
WHAT THE HELL?!
Code 13, now known as the 'your motor is severly damaged' code. How does it skip 7 teeth? Actually, how did you not notice that? Whoa. Well, at least you figured it out and are doing it right!
Old Dec 10, 2013 | 07:53 PM
wing.jai's Avatar
when we bought the car previous owner told us timing belt was recently change, i even double check it it was good but after the 1 1/2 pass, I forgot to check up on it (which is my fault ). everytime i crank the car its would backfire n felt like timing was off so i pop out the timing belt cover and timing was off so i crank it slowly by hand and saw 7th teeth broke from the belt. lol
Old Dec 11, 2013 | 03:00 AM
Whoa, broke off the belt. That has to be some nasty dry rot.
Jsl9299
Engine Management and Tuning
Nov 2, 2018 09:10 AM
C4st0r_Tr0y
Honda Civic (2001 - 2005)
Aug 12, 2018 08:08 AM
CPEF9
Sep 11, 2016 02:45 PM
AMseven
Sep 22, 2009 08:37 AM
