Should VTEC work with the O2 sensor disconnected with a P28?
Old Oct 25, 2002 | 06:26 PM
jonnybravo's Avatar
Default Should VTEC work with the O2 sensor disconnected with a P28?
Old Oct 25, 2002 | 06:35 PM
Cosworth's Avatar
Default Re: Should VTEC work with the O2 sensor disconnected with a P28? (jonnybravo)
you mean as in primary O2 sensor or secondary O2 sensor?
you won't need secondary O2 sensor reading w/ P28, so vtec will work just fine. I don't think you can run w/o primary O2 sensor what-so-ever.
Old Oct 25, 2002 | 06:43 PM
jonnybravo's Avatar
Default Re: Should VTEC work with the O2 sensor disconnected with a P28? (Cosworth)
It's the primary(I have a 96 JDM motor). This is my situation. A friend on mine is using my SMS header for a track event this weekend and loaned me his JDM 4-1. Well as most of you know, the O2 sensor wire has to be extended pretty far so I just loaned out the O2 also. He didn't have a O2 on his 4-1 so we put it on my car without it. Car start but no VTEC and you can tell it's running really rich. So is it normal for VTEC not to work?
[Modified by jonnybravo, 8:30 AM 10/26/2002]
Old Oct 25, 2002 | 09:20 PM
sgT's Avatar
sgT
vtec should work fine without the primary O2
Old Oct 25, 2002 | 09:56 PM
Tommy_Gunns's Avatar
So you lent him you O2 sensor but he didn't lend his to you...what a jackass
shredderkid322
12
May 8, 2012 06:10 PM
phoshyzzle
Oct 18, 2009 07:52 PM
mxl36o
Aug 4, 2006 06:09 PM
Kirk@SyndromeAuto
Feb 24, 2005 03:47 PM
