Fully Built H22 SFWD project part out - AEM Kaizenspeed LSD Golden Eagle
Means of contact: 804 551 8247
Price: $$$$
Description:
I've been considering some different options lately so let's see how this goes. I am in no way at all in a rush to let this stuff go, I'm not even sure I'll sell it if my asking price is met. If I do decide though, the long block will need to be the first thing to go. Unless you see that is sold don't bother asking to buy any of the other parts. I'm only selling this stuff in the order listed. So if item #3 isn't sold for example don't ask to buy item #6 unless you plan on buying #3, 4 and 5 also. I have numerous people that can vouch for all these parts.
#1. Fully built H22A longblock - Motor was assembled about a year ago, since then it has seen 2 dyno sessions, 2 track passes, 10-15 street passes and maybe 600 normal driving miles. I have all paperwork for the motor getting built with all the specs the builder used. Built at Laurel Automotive and has never smoked one bit or had the slightest problem. Car made 490 on 17psi. That is a little over half the potential this motor has. Longblock will come with valve cover, fully assembled head, vtec solenoid, fully assembled bottom end, and oil pan. If it's not listed it's not included.
Head:
Skunk2 Pro 1 Cams
Skunk2 Cam Gears
Skunk2 Springs and Retainers
Brian Crower stock size valves
Supertech valve seals
Bottom End:
Darton sleeved closed deck H22A bottom end
ARP head studs
Cometic stock bore head gasket
CP 9:1 pistons
Eagle H Beam rods
ACL main and rod bearings
ARP main bolts
Kaizenspeed balance shaft delete
Kaizenspeed manual tensioner
Etc:
Valve cover w/ 2 -10an bungs
Gates Racing timing belt
New OEM crank pulley
New OEM idler pulley
I'm probably forgetting a few things but I'll add them as I remember.
$3,000
#2: H22A4 Transmission
OBX LSD w/ 500-600 miles
Brand new OEM diff bearings
No grinds, pop outs, etc.
$600
#3: Golden Eagle Intake Manifold w/ matching fuel rail
Does not include throttle body or injectors
$650
#4: AEM COP Setup w/ Version 2 OBD2A ECU
Has 2 dyno sessions and 50 driving miles on the whole setup
EPM
K series coil packs
Custom Momentum Autoworks coil pack harness
$1,500
#5: Kaizenspeed Forward Facing H22 Manifold
Bought from Reid at Kaizenspeed (Have receipt)
Used for a short time on their H2B EK Hatch
T4
Twin 60mm wastegates
Black ceramic coated
$850
I can be reached at 804 551 8247 for more info or pics
Pictures:
Price: $$$$
Description:
Head:
Skunk2 Pro 1 Cams
Skunk2 Cam Gears
Bottom End:
ARP head studs
CP 9:1 pistons
Eagle H Beam rods
ARP main bolts
Etc:
$3,000
$600
$650
EPM
K series coil packs
$1,500
T4
$850
Pictures:
EKfiend
Sep 7, 2013 07:11 AM
One 38
Jul 15, 2003 11:56 PM
