using d10 for wideband datalog
I'm using an mtxl I'm my 94 civic with s300.
I've removed r136 & r138 from the board as described in the s300 help file.
My main questions are:
Under the misc tab does eld need to be enabled? It's currently disabled.
On my display screen in s300 I have added a value for afr and for eld, neither display anything remotely close to my wideband gauge.
I'm stumped. Appreciate the help
ELD needs to be disabled. In the most current SManager you should only have to modify the voltage scale in the closed loop parameter. If it's still off, chances are your ground is noisy or your wideband may be defective.
Try simulating a constant voltage to the input (i.e. MAP power wire with a 1k resistor) and see if it gets the same reading as your voltmeter to ground. If not, probably a ground issue or possibly a bad ECU.
Or you could just use D14 or an analogue input on the S300 and avoid the headache altogether.
Wideband is grounded at tstat like the instructions said. The xenocron article I ran across said to ground at the ecu I think pin a24 (or a25).
I think I got that stuff figured out. How do I get smanager to display the value in afr vs a voltage?
Thanks for the help
Thanks for the help
Right click on AF in the sensors window and click on propertys
Change from lamda to air fuel
Go into options, settings, units & select air fuel ratio & click ok.
Finally had a chance to check everything out...
Everything is set up the way mtber advised.
I can not change from voltage to afr/lambda scale in the sensor set up window...
plx and s300 problemsjust bought a plx sm-afr. hooked it up through the eld and ground to the batter
sohctodohc
Engine Management and Tuning
Jul 14, 2008 05:02 PM
