A/C Issues..Take a look please
Old Aug 30, 2013 | 04:58 PM
ooopseyesharted's Avatar
Default A/C Issues..Take a look please
I have a 96 Accord Ex wagon.
Vtec engine.
When I have the AC on in stop and go traffic the temp gauge goes up.
I shut off the ac the temp goes right back down.
I have checked the anti freeze and it is all good.
What am I missing?
I need to get this fixed...I roasted my nuts today in traffic! LOL
Old Aug 30, 2013 | 05:23 PM
NZXTInerTia's Avatar
Default Re: A/C Issues..Take a look please
Is your fan engaging properly?
Old Aug 30, 2013 | 05:30 PM
It seems to be. Is there a way to check it?
I know its on when the car gets warm.
Old Aug 30, 2013 | 09:34 PM
holmesnmanny's Avatar
You could try looking at it. See if it's on when the car is starting to overheat. There are two fans. Make sure both are running when the ac is on and the compressor is on. They should also be running together when the ac is not on. If only one is working at any time while the car is on then something is wrong and make a note of which one is not running.
Old Aug 31, 2013 | 05:13 AM
Fitz Williams's Avatar
10 Year Member
Vtec engine.
What am I missing?
I have had this problem on a couple of cars, one not Honda. Notably when I switched from R12 to R134a. The AC condenser must put out a lot of heat when the weather is hot.
Old Aug 31, 2013 | 02:21 PM
Only the drivers side fan comes on when the ac is on.
I will drive it around later and see if it comes on when the car gets warm.
Old Sep 1, 2013 | 02:06 AM
ok report back
Old Sep 1, 2013 | 04:01 AM
Lost Again's Avatar
Huh.....you have found the issue? I would start testing "why" the pass side fan is not coming on.
Put 12v to the motor, does it run....if so start working your way back up the circuit (relay, fuse, connections, ect).
Old Sep 1, 2013 | 10:53 AM
I drove the car back from Erie, PA to Cleveland today. All highway and no issues. But the passengers side fan does not work.
I got home and popped the hood. As the car fans turned on, only the drivers side worked.
I will check the drivers side fan a little later.
Old Sep 1, 2013 | 01:52 PM
djkurious's Avatar
When the AC button is pressed, both fans start spinning. If not take 12v to the non-working fan. If it doesn't spin with 12v applied to it, fan is bad=replace.
typeRef
Jun 1, 2012 07:36 PM
khenning
Sep 15, 2005 05:52 AM
Gir
May 30, 2003 04:03 AM
