90 hatch/LSv swap...sorta runs but have codes.
Old Aug 30, 2013 | 03:32 PM
lowN$low's Avatar
Default 90 hatch/LSv swap...sorta runs but have codes.
i'll start out with what im working with
-90 civic hatch
-B18a1/GSR LSV
-LS trans
-B16A P30 ecu(stock) and obd1 dizzy to match(i had to splice my obd0 plugs to the obd1 dizzy as the idiot who took the harness off the LS teggy i swiped it from at the yard just cut the plugs off)
-home done motor harness to best of my ability.
now the issues
-has a revving issue were the car will some times rev to 4500 tops then its random and doesnt run well when driving but idles just fine at 800-1k when warm.
-has no power in 3rd
-has the following codes
Code 6 Engine coolant temperature
Code 9 No.1 cylinder position sensor
Code 10 Intake air temperature sensor
Code 14 Idle air control valve or bad ECM
Code 20 Electric load detector
any help id appreciate very much.
99y8
Sep 9, 2012 09:31 PM
blackwagon
Nov 16, 2010 07:15 AM
bababab18
Sep 30, 2010 01:30 PM
manuel3655
May 21, 2007 07:41 AM
05si90hatch
Nov 14, 2006 08:49 AM
