Honda CR-V & Element 2WD & 4WD Element & CR-V
crv just died
Old Aug 30, 2013 | 09:40 AM
Allday Dabbin's Avatar
Default crv just died
So we went on a trip. we got 160 miles got hungry and went to taco bell. while waiting on the food the crv just died no noises no warning but the naint reqd light popping on which we thought nothing off. tried jumping it but it has power so not the battery. friend is leaning towards timing belt? any pointers would be appreciated
Old Aug 30, 2013 | 10:10 AM
kiseliok's Avatar
Default Re: crv just died
So I'm guessing it's still cranking, just won't idle? Fuel pump, maybe?
Old Aug 30, 2013 | 01:17 PM
Sticker Bomb's Avatar
Easy way to tell if it's a timing belt is remove the oil cap and have someone try to start it while you are looking at the valve train. You should see it moving when it's cranking, if not, then the timing belt snapped.
Old Aug 30, 2013 | 01:59 PM
blk1stgen's Avatar
this
you should see the cams spinning while it's cranking ...if they spin, timing belt is ok , look at other possibilities.
also check the distributor, the 97-01 CRV's are notorious for having bad distributors.
removed a spark plug wire, hold close to the engine, and have someone crank the ignition, if distributor is good, you should see sparks grounding to the engine
Old Aug 30, 2013 | 04:21 PM
sorry it is an 06 crv. totally forgot to say that. i do not know how else to put this but when trying to turn it over the engine acts as if it has no power making an almost identical sound to an almost dead battery. we tried a jumper pack and jumping it so pretty sure battery is not the issue. also all the accessories work windows headlights.
Old Aug 31, 2013 | 06:46 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Bad starter.
Old Aug 31, 2013 | 07:35 PM
jesse95's Avatar
Originally Posted by Caoboy
Bad starter.
Bad starter won't make it die.
Maybe bad alternator. Not charging the batt causing it to die. Get a direct jump from another car because sometimes those jumpers are not strong enought start it.
My $0.02
Old Aug 31, 2013 | 08:24 PM
PixieTrix's Avatar
The valves might have tightened up. Happened to mine, had to replace the head. Apparently it is common with CR-Vs, but mine is an 01, not sure if it is common with 06.
Old Aug 31, 2013 | 10:03 PM
ARMED's Avatar
hahahah i actually said that? bad starter? i must be drunk...
Old Sep 1, 2013 | 03:05 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
My $0.02
Didn't read the 'just died' part.
Thought he went to start it and it just clicks.
Caoboy's Avatar
-Intl Steve Krew
Loved
You must be drunk, because I said that LOL.
Semper Fi!
WrenchinRosie
Jan 24, 2015 08:05 AM
doc500
Apr 13, 2012 05:52 PM
JCracer723
Aug 19, 2007 01:38 AM
valve79
Dec 29, 2004 03:20 AM
aqttran
Jul 26, 2002 08:19 PM
