D16Y8+AEM METH INJECTION+EAGLE RODS+ FULL-RACE+GREDDY INTERCOOLER+TURBO TIMER+ITR CAM
Old Aug 30, 2013 | 07:35 AM
BoostedDOHCGSR's Avatar
10 Year Member
Icon7 D16Y8+AEM METH INJECTION+EAGLE RODS+ FULL-RACE+GREDDY INTERCOOLER+TURBO TIMER+ITR CAM
Location is PALMDALE, CA 93551
Can and will ship at buyers expense. Paypal ready.
Turbo Cam Package.
95-00 JDM ITR intake cam and B16 exhaust Cam.
Made over 600+WHP with this Combination. Upgraded to PRO1s.
$150
Eagle Rods
used but in perfect working order
LS/B20 sized
ARP 2000 Rod Bolts
Upgraded to Turbo tuff Rods.
$220
Honda OEM LS Crank
Prepped by Castillo Crank for the FCS Integra.
Oil galleys Chamfered
Journals polished
Ready to drop in.
$150
COMPLETE AEM INJECTION KIT
AEM Meth Injection Kit #30-3000
With AEM Meth Filter #30-3003
BRAND NEW! Installed but Never RAN!!
Universal kit includes everything you need for installation
Boost Safe lets you retard the timing or reduce boost if the system runs out of fluid or detects an error
Progressive, controller-driven 150-PSI pump provides boost-dependent variable flow
Dash light for system status and low fluid warning
Change of Plans.
$300
VP M1 Methanol 5 Gallon Pail
Was going to mix for AEM kit. Never Used or opened.
Change of Plans.
$20
TRUST GREDDY Type 24 Intercooler.
276x600x76mm 2.5In and out. As measured CORE: 23.5x 2.75x 11
This Type 24 is part of Trust's newest lineup of intercoolers and is the absolute top of the line in cooling and build quality!! The Trust Intercooler Core is designed to support the most power (high-boost) with the absolute best cooling efficiency and the lightest weight unit available from Trust. It is
recommended for full-tuned engines with large turbine kits.
The intercooler has tube-type cooling passages and off-set inner fin cooling passages for an extremely lightweight and efficient setup.
http://www.evasivemotorsports.com/mm...FQJBQgodS3kAAg
Intercooler was painted ceramic flat black on side facing foward.
Intercooler is dented on the bottom of it. You cannot see it once installed.
Intercooler made over 600WHP and held 28psi of boost.
Tabs are welded to install in a Civic and Integra.
$150
Greddy Turbo Timer
Acquired this in a trade. Never installed or tried.
Designed to prolong the life of your turbocharger, while adding connivance. Greddy Full Auto Turbo Timers allow a vehicle to idle the engine for a timed
period, with the ignition key removed. This conveniently allows the engine oil and turbo center cartridge to cool down properly and prolong turbo and oil
life. This can be done by two standard programmable count down presets (P-1, P-2), or the GReddy Full Auto Timer can use it’s two auto timer modes (A-L, A-H). The modes estimate the driving RPM according to the vehicle's alternator signal and then recommend a count down time.
http://www.greddy.com/products/elect.../turbo-timers/
Letting it go cheap because I never tried it.
$20
ITR RHD PASSENGER Carbon Fiber Switch
REAL JDM ITR PART
$20
JDM Road FLARE
Found in EK9s I believe.
$10
D16y8
Missing Oil Pan, Dizzy and Timing belt.
Blown HeadGasket.
Friend upgraded to B series
$250
Full-Race Shift ****
2 Laser etched Full-Race Logos
Hard Anodized black
12X1.25 Thread Pitch
Performance Shift Grip Design
http://www.full-race.com/store/acces...hift-****.html
slight Blemish can be seen on Photo
$20
Old Aug 30, 2013 | 07:37 AM
10 Year Member
Default Re: D16Y8+AEM METH INJECTION+EAGLE RODS+ FULL-RACE+GREDDY INTERCOOLER+TURBO TIMER+ITR
More Pics
Old Aug 31, 2013 | 05:00 AM
10 Year Member
Bumpo
Old Aug 31, 2013 | 07:19 PM
10 Year Member
ttt
Old Sep 1, 2013 | 09:08 PM
10 Year Member
ttt
Old Sep 2, 2013 | 10:13 PM
10 Year Member
ttt
Old Sep 3, 2013 | 12:06 PM
10 Year Member
ttt
WHY7SPOOLIN
Jul 12, 2014 02:40 PM
BoostedDOHCGSR
Sep 10, 2013 06:05 PM
BoostedDOHCGSR
Sep 10, 2013 05:50 PM
cyanid3
Nov 28, 2010 02:41 PM
luis80
May 25, 2010 01:14 PM
