AEM METH INJECTION+EAGLE RODS+TRUST+GREDDY+ITR CAMS+FUL-RACE+OEM CRANK+D16Y8
Old Aug 30, 2013 | 07:30 AM
BoostedDOHCGSR's Avatar
10 Year Member
Icon7 AEM METH INJECTION+EAGLE RODS+TRUST+GREDDY+ITR CAMS+FUL-RACE+OEM CRANK+D16Y8
Location is PALMDALE, CA 93551
Can and will ship at buyers expense. Paypal ready.
Turbo Cam Package.
95-00 JDM ITR intake cam and B16 exhaust Cam.
Made over 600+WHP with this Combination. Upgraded to PRO1s.
$150
Eagle Rods
used but in perfect working order
LS/B20 sized
ARP 2000 Rod Bolts
Upgraded to Turbo tuff Rods.
$220
Honda OEM LS Crank
Prepped by Castillo Crank for the FCS Integra.
Oil galleys Chamfered
Journals polished
Ready to drop in.
$150
COMPLETE AEM INJECTION KIT
AEM Meth Injection Kit #30-3000
With AEM Meth Filter #30-3003
BRAND NEW! Installed but Never RAN!!
Universal kit includes everything you need for installation
Boost Safe lets you retard the timing or reduce boost if the system runs out of fluid or detects an error
Progressive, controller-driven 150-PSI pump provides boost-dependent variable flow
Dash light for system status and low fluid warning
Change of Plans.
$300
VP M1 Methanol 5 Gallon Pail
Was going to mix for AEM kit. Never Used or opened.
Change of Plans.
$20
TRUST GREDDY Type 24 Intercooler.
276x600x76mm 2.5In and out. As measured CORE: 23.5x 2.75x 11
This Type 24 is part of Trust's newest lineup of intercoolers and is the absolute top of the line in cooling and build quality!! The Trust Intercooler Core is designed to support the most power (high-boost) with the absolute best cooling efficiency and the lightest weight unit available from Trust. It is
recommended for full-tuned engines with large turbine kits.
The intercooler has tube-type cooling passages and off-set inner fin cooling passages for an extremely lightweight and efficient setup.
http://www.evasivemotorsports.com/mm...FQJBQgodS3kAAg
Intercooler was painted ceramic flat black on side facing foward.
Intercooler is dented on the bottom of it. You cannot see it once installed.
Intercooler made over 600WHP and held 28psi of boost.
Tabs are welded to install in a Civic and Integra.
$150
Greddy Turbo Timer
Acquired this in a trade. Never installed or tried.
Designed to prolong the life of your turbocharger, while adding connivance. Greddy Full Auto Turbo Timers allow a vehicle to idle the engine for a timed
period, with the ignition key removed. This conveniently allows the engine oil and turbo center cartridge to cool down properly and prolong turbo and oil
life. This can be done by two standard programmable count down presets (P-1, P-2), or the GReddy Full Auto Timer can use it’s two auto timer modes (A-L, A-H). The modes estimate the driving RPM according to the vehicle's alternator signal and then recommend a count down time.
http://www.greddy.com/products/elect.../turbo-timers/
Letting it go cheap because I never tried it.
$20
ITR RHD PASSENGER Carbon Fiber Switch
REAL JDM ITR PART
$20
JDM Road FLARE
Found in EK9s I believe.
$10
D16y8
Missing Oil Pan, Dizzy and Timing belt. Manifolds.
Blown HeadGasket.
Friend upgraded to B series
$250
Full-Race Shift ****
2 Laser etched Full-Race Logos
Hard Anodized black
12X1.25 Thread Pitch
Performance Shift Grip Design
http://www.full-race.com/store/acces...hift-****.html
slight Blemish can be seen on Photo
$20
Old Aug 30, 2013 | 07:31 AM
10 Year Member
Default Re: AEM METH INJECTION+EAGLE RODS+TRUST+GREDDY+ITR CAMS+FUL-RACE+OEM CRANK+D16Y8
More Pics.
Old Aug 30, 2013 | 12:25 PM
LSVTEf's Avatar
u got cash in your paypal!!
Old Aug 31, 2013 | 04:59 AM
10 Year Member
Thankyou
BUMPS!
Old Aug 31, 2013 | 07:20 PM
10 Year Member
ttt
Old Sep 1, 2013 | 12:54 AM
LSVTEf's Avatar
Can u pm me some shipping info when u get it..... thanks!
Old Sep 1, 2013 | 09:01 PM
10 Year Member
should be Tuesday. Will PM you! thanks for the bumps!
Old Sep 2, 2013 | 10:13 PM
10 Year Member
ttt
Old Sep 3, 2013 | 12:06 PM
10 Year Member
ttt
Old Sep 5, 2013 | 09:18 AM
LSVTEf's Avatar
yo its now Thursday and no part or shipping info.... could you send me the shipping info asap!!!!!i! thanks!
Old Sep 6, 2013 | 08:18 AM
LSVTEf's Avatar
Old Sep 6, 2013 | 05:05 PM
10 Year Member
shipping info sent!
Old Sep 8, 2013 | 09:17 AM
Zer0_SpeedWorks's Avatar
Aem still there?
Old Sep 9, 2013 | 11:22 AM
LSVTEf's Avatar
i would not buy from this person ever!!!! i payed with paypal on Aug 30, 1:20pm he did not ship till September 6, 2013, 5:18 pm.... When i got my parts September 7, 2013, 4:26 pm i open the box that has the ITR RHD PASSENGER Carbon Fiber Switch in about 4 pieces... it was all taken apart not sure y and the part that holds it in the door is broken!!!! in the pics he has up the part is in one piece and he did not say anything about broken parts!!!!
just to let people know if you buy from him ask for more pics and info!!!
Old Sep 9, 2013 | 12:40 PM
10 Year Member
1st off I do not ship until money clears.
I told you that from the start. Money did not clear until Wednesday Sept. 4th.
I should've shipped out Sept 5th. That's my error. I shipped out Sept 6th.
2nd
In order for it to fit in the $5 shipping box I had to take it apart. It was only two small screws. if you would like I can show you how to put it together.
I did not know it was broken.
Is the part that holds it into the door in the box? It shipped with $50 Insurance.
Why did you not PM me on this issue instead of just coming on here and trying to blast me?
I have things for sale that are up to $300 dollars I am not going to ruin my screenname over some $20 part you bought from me. I am a very Legit seller.
If you would like to take care of this in some way pm me.
Full refund can be giving if you ship the part back to me.
We can discuss a partial refund or some other way of dealing with this if you message me.
BUMP TTT Still have everything except for the RHD Switch.
Old Sep 9, 2013 | 04:42 PM
LSVTEf's Avatar
u will have a pm when i get off work!
Old Sep 10, 2013 | 06:05 PM
10 Year Member
TTT
BoostedDOHCGSR
Sep 10, 2013 05:50 PM
overratedstyles
Nov 20, 2012 03:15 AM
1sicef9
Jul 23, 2011 12:25 PM
AFFIRMED
Aug 24, 2004 09:37 PM
