NEED GONE ASAP! tial, goautoworks, itr cam, and more
Trying to get alittle cash together in a hurry so I've got a few parts layin around that I'm going to price very cheap but only for the next couple of days because that's how long I have to come up with the money so after that the prices may go up or ill just keep what I haven't sold. So that being said I'm open to offers and don't worry about low balling because I'm doing it for you. Thanks.
Tial 50mm bov silver not sure on the spring rate has a few scatches from normal use but it works just fine. -100.00
Tial 38mm 2 bolt flange wastegate with 8psi spring has a few scratches like the bov from use but works perfect. -100.00
Itr intake cam. This cam came in a motor that I baught and was told it was an itr cam but I did look into the indentification of the cam and It has the 2 grooves at the end of the cam on the distributor side and from the info I've found it seems to be a legit itr cam. If anyone knows alittle more about it feel free to correct me if I'm wrong. -100.00
Backdoor intercooler 32x9x4.5 with 2.5" inlet/outlet. I baught this off a buddy of mine and he said it was a go autoworks ic but there is no identifaction on it to prove that it is a go autoworks but it is a quality ic non the less and held 513whp no problem but am unsure the core rating. When my buddy had it he made a little over 600 whp so it can handle quite a bit.-200.00
Speed factory 4 bar map sensor. Barely any use on this maybe 300ish miles. -40.00
Go autowork 3" upper cold side ic pipe with tial 50mm bov flange painted black. Has some wear on it from my catch cqn lines rubbing on it but still works -30.00
Obd2a to obd1 jumper harness. New never used. -15.00
Garrett 57 trim t3/t4 4 bolt downpipe turbo in great shape I just took it off my dd. I made 302whp at 12psi on a bonestock ls with this little guy and it has been a great turbo. Has zero in/out play and hardly any side/side play only thing wrong is the bolt holes for the downpipe need to be helicoiled because the bolts broke off in the housing. I attempted to drill them out and retap the holes but I had a tap break in one hole and gave up but this would b an easy task for most machine shops. The exhaust housing is. 63ar and compressor housing is .60ar. -250.00
Blox vacuum block (black) a few scratches but notjing major works fine. -20.00
I've got a few other misc parts layin around but thats all I've got for the moment. Text me for any ??s 270-929-3375. Likeni said I'm tryin to move this stuff asap so no reasonable offer will be ignored. Thanks
civicdragger818
10
Jun 16, 2004 08:26 AM
