Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
Grams Performance Fuel Injectors / Now in Stock / Authorized Dealer
Old Aug 28, 2013 | 10:50 AM
amrodtech's Avatar
Default Grams Performance Fuel Injectors / Now in Stock / Authorized Dealer
We are having a Sale on all Grams Performance Fuel Injectors. Grams Performance is proud to offer the most innovative high-performance fuel injectors for today’s performance vehicles. Premium materials, advanced manufacturing techniques, and stringent quality control procedures make Grams Performance the leader in high-performance fuel injectors.
An engine’s fuel injectors perform a vital role in the accurate metering and atomization of fuel. Grams Performance accomplishes this with its high-impedance Bosch Motorsports EV14 fuel injectors that are modified for high-performance use. Each injector is individually balanced, flow tested, and dynamically matched for characterization within one percent of one another. To ensure leak-free operation and optimal performance, each injector is then pressure tested up to 220 psi. The results are unmatched cylinder-to-cylinder consistency, even at low pulse widths, as well as optimal idle quality, response, and performance. Grams Performance Fuel Injectors’ ultra-fast and precise solenoids feature a linear response curve across a wide range of operating conditions and can accurately meter fuel even at the highest pressures and shortest pulse widths.
The EV14 injector’s superior ball/pintle valves combined with Grams Performance’s precision-modified nozzles allow for consistent performance up to 118 psi, making them suitable for a wide range of applications, yet without exhibiting any of the high-pressure problems often associated with other injectors. The optimized spray pattern also helps improve mixture preparation as well as atomization.
Grams Performance injectors are cold-cut with diamond grinders in less than three seconds for high precision without “pre-seating.” Abrasive cutting creates heat, which leads to poor spray patterns and the need for competitors to pre-seat their injectors to reduce distortion. Each injector is also fitted with high-quality Viton O-rings that are resistant to extreme temperatures and harmful oils found in some fuels.
Each injector set includes dead time compensation values to help ensure consistent air/fuel ratios and optimal performance when tuning. Grams Performance Fuel Injectors are carefully tested and matched in controlled laboratory environments using state-of-the-art equipment and are subjected to rigorous dyno, street, and race track testing to ensure proper performance in the most extreme conditions.
FEATURES:
High-impedance design (no resistor box required)
Cold-machined tips for high-precision operation
Ultra-fast solenoids for precise fuel metering
Linear response across wide range of operating conditions
All injectors balanced, blueprinted, and matched within one percent
Compatible with all known fuels including gasoline, methanol, and ethanol
Unmatched cylinder-to-cylinder consistency and optimal idle quality
Watch the Grams Performance Injector Video -
*** B / D / H / K Series 550, 750, 1000, 1150 and 2200's in Stock ***
*** Click Link Below to Order Your Injectors ***
http://www.importdpsonline.com/grams...s/g-67541.aspx
We accept Visa, Mastercard, American Express, Discover and Paypal. Call me at 215-227-6000 if you have questions or would like to order by Phone!
We are adding the 1150's and 2200's to the Site as we post this. In Stock In Store Pickup are always welcome! PA Residents must pay 8% Sales Tax. Orders Ship FEDEX Ground Free of Charge!
Thanks
Import DPS
Old Aug 29, 2013 | 07:17 AM
amrodtech's Avatar
Default Re: Grams Performance Fuel Injectors / Now in Stock / Authorized Dealer
Fuel your Whip!! Grams Performance and Design Injectors
Old Aug 29, 2013 | 01:05 PM
amrodtech's Avatar
Thursday Evening Bump!!!
Old Aug 30, 2013 | 10:36 AM
amrodtech's Avatar
Friday Afternoon Bump!!!
Old Aug 31, 2013 | 10:41 AM
amrodtech's Avatar
In Stock!!!!
Old Sep 3, 2013 | 08:39 AM
amrodtech's Avatar
Tuesday Bump!!!!
Old Sep 5, 2013 | 10:05 AM
amrodtech's Avatar
Thursday Bump!!!
Old Sep 6, 2013 | 07:23 AM
amrodtech's Avatar
Friday Bump!!!!
Old Sep 7, 2013 | 05:48 AM
amrodtech's Avatar
Parts in Stock here at Import DPS!
Old Sep 9, 2013 | 10:14 AM
amrodtech's Avatar
Monday Bump!! Go Eagles!
Old Sep 13, 2013 | 10:22 PM
amrodtech's Avatar
Saturday Middle of the Night Bump!!
Old Sep 18, 2013 | 11:29 AM
amrodtech's Avatar
Weds Bump!!!!
Old Sep 19, 2013 | 10:10 PM
amrodtech's Avatar
Friday Morning Bump!!!
Old Sep 23, 2013 | 03:21 PM
amrodtech's Avatar
Monday Bump!!!
Old Oct 1, 2013 | 10:09 PM
amrodtech's Avatar
Weds Bump!!!
Old Oct 10, 2013 | 08:02 PM
amrodtech's Avatar
Old Oct 19, 2013 | 09:15 AM
amrodtech's Avatar
Saturday Morning Bump!!!
Old Oct 22, 2013 | 08:23 AM
amrodtech's Avatar
Tuesday Bump!!!
Old Oct 30, 2013 | 09:18 AM
amrodtech's Avatar
Weds Bump!!!!!
Old Nov 6, 2013 | 09:45 PM
amrodtech's Avatar
Thursday Bump!!!
Old Nov 8, 2013 | 12:00 PM
amrodtech's Avatar
Friday Bump!!!!
Old Nov 11, 2013 | 08:30 PM
amrodtech's Avatar
Tuesday Bump!!
Old Nov 21, 2013 | 08:53 AM
amrodtech's Avatar
Thursday Bump!!!!
Old Dec 2, 2013 | 11:39 AM
amrodtech's Avatar
Monday Bump!!!!
Old Dec 6, 2013 | 05:04 PM
amrodtech's Avatar
Friday Night Bump!!!
