Can someone verify this 5-lug conversion? 5th Gen Accord
5th Gen Accord (1994 LX - Manual Trans)
FRONT:
Accord V6 Knuckles (1995):
51210-SX0-902 (Front Right) 1 225$ HPD $168.52
51215-SX0-902 (Front Left) 1 225$ HPD $168.52
Odyssey Wheel Bearings (1996):
44200-SX0-008 (Front) 2 202$ HPD $76.14
Odyssey Hubs (1996):
44600-SX0-000 (Front) 2 390$ HPD $145.45 Each
Prelude Front Calipers (1995):
06452-SM5-505RM (Front Right) 1 95$ HPD $71.46
06453-SM5-505RM (Front Left) 1 95$ HPD $71.46
Trying to double check this conversion.
Rear is:
97+ Rear Prelude Hub/Bearing Assemblies
42200-S30-C51 (Rear) HPD $113.27
1995 Accord EX Rear Calipers
43019-SV4-A00 (Left Rear) HPD $116.01
43018-SV4-A00 (Right Rear) HPD $116.01
Rear Parking Brake Cables:
47560-SV1-951 (Left) HPD $53.50
47510-SV1-951 (Right) HPD $54.58
Can someone confirm?
FRONT:
Rear is:
Accord Gen 5 V6 knuckles and Odyssey 95-98 are the same (knuckles are the same, hubs are not.). Gen 6 Accord knuckles are not the same. They might work. I looked into it but it didn't seem worth the effort since the others will work and are easily available. Problem with the Gen 6 is that the geometry between the mounting points has to be the same or you will end up with different camber and possibly a different front track width. I took measurements on the bench with a Gen 5 and a Gen 6 knuckle and they looked really close. I would love to see someone give it a try, but I am not suggesting it.
One other minor consideration, the brake lines on the Gen 5 mount on the knuckle, the Gen 6 is different. Also, I am not sure if the length of the axle is the same between the two.
Most all Honda calipers will interchange. It's the brackets that are different. Some have different mounting points and different offsets. But a V6 Gen 5 Accord caliper, or a 95-98 Odyssey caliper, and bracket should be no problem. But you may have to choose the bracket by the diameter and width of the rotor you will use. Centric lists the same rotor for the Odyssey and the 97 Prelude. Both are 282 mm (11.1 inch) so you will need the 23T or 25T bracket. The rear is not an issue with the 95 Accord brackets. Just use the 98-02 V6 rear rotor and not the Prelude one.
I think the "S5" stamped knuckles( S5 is actually stamped on the brake dust covers) hubs rotors and calipers will swap over to the accord chassis.
SQ is the SQUAD
Apr 20, 2011 04:38 PM
porter843
Dec 7, 2004 05:06 PM
