Idle issue
Old Aug 27, 2013 | 05:08 PM
swankmotee's Avatar
Default Idle issue
I have cleaned my IACV and checked all lines,adjusted idle screw with IACV unplugged then disconnected the battery to reset the ECU and reconnected and STILL can't get it to go below 15K on the rpm's. Am I missing something or is the IACV bad?
Old Aug 27, 2013 | 05:44 PM
d=f20c1's Avatar
Default Re: Idle issue
Throttle cable too tight. Clean the spring on the throttle body
Old Aug 27, 2013 | 07:10 PM
itr#1334's Avatar
I think you mean 1.5k lol. Does it fluctuate at all?
Old Aug 28, 2013 | 05:22 AM
swankmotee's Avatar
HA, yes a typo and it does the usual up and down when the fans kick on. I will check the cable though.
UPDATE 9/5/13. Replaced IAC valve and it's working fine now!
Old Sep 25, 2013 | 08:39 AM
ranutk's Avatar
Hi,Do you have partsnumber?(IACV)
gabrielsousa
May 2, 2014 07:53 AM
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
asocallocal
Sep 23, 2010 06:20 PM
emooheo
Mar 23, 2007 02:34 PM
wantmorepower
Aug 21, 2001 12:08 PM
