Integra Fuel Pump Info
Old Aug 27, 2013 | 12:23 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Integra Fuel Pump Info
Reading conflicting info about the flow rates of various Integra fuel pumps prompted me to do a little research. I thought I would share my results for future searchers....
The OEM manuals only explain pump flow rates for the 94-95 years (couldn't find 96-97 shop manual to confirm). The funny thing is the flow rates are mysteriously absent from the 98+ shop manuals specs. When I started checking part numbers of the pumps, I found some odd information. The VTEC models only use a specialized higher-flowing pump for the 94 thru 97 model years. Then I found out that Denso was the OEM supplier of Honda's pumps and they offered the following info about the various models used in the 3G Integra:
94-01 Integra GS/RS/LS = 80 Lph "new" spec in shop manual (Denso says same)
94-95 Integra GSR = 131 Lph "new" spec in shop manual, 119 Lph from Denso
96-97 Integra GSR & Type R = 110 Lph from Denso
98-01 Integra GSR & Type R = 80 Lph from Denso (confirmed by part number)
Here are the OEM part numbers (for complete pump hangar assemblies) next to the Denso pump number to help back up this info:
94-95 GS/RS/LSL: 17040-SR3-A31 951-0004 (80 Lph)
96-97 GS/RS/LS: 17040-S04-G41 951-0004 (80 Lph)
98-01 GS/RS/LS: 17040-ST7-L31 951-0004 (80 Lph)
94-95 GSR: 17040-ST7-A31 951-0006 (119 Lph)
96-97 GSR/TypeR: 17040-ST7-A33 951-0005 (110 Lph)
98-01 GSR/TypeR: 17040-ST7-L31 951-0004 (80 Lph)
So for whatever reason, it seems Honda started the 1.8L VTEC line of motors off with the biggest pump, and slowly scaled it back to the 80 LPH model found in all Non VTEC Integras & Civics for the later years.
Interestingly you find the Denso 951-0005 110 Lph (pump only) in the following cars:
01-03 Acura CL
96-97 Acura Integra GS-R
97-97 Acura Integra Type R
01-02 Acura MDX
02-06 Acura RSX
02-03 Acura TL
02-06 Honda CR-V
99-04 Honda Odyssey
03-04 Honda Pilot
97-01 Honda Prelude
00-03 Honda S2000
04-05 Honda S2000
The Denso 951-0006 119 Lph (pump only) is found in the following:
94-95 Acura Integra GS-R
94-95 Acura Legend GS
91-95 Acura Legend
96-04 Acura RL
The Denso 951-0004 80 Lph (pump only) is found in:
97-99 Acura CL
97-97 Acura CL
98-99 Acura CL
01-02 Acura CL
97-97 Acura Integra GS
94-97 Acura Integra LS
94-97 Acura Integra RS
95-96 Acura Integra Special Edition
98-01 Acura Integra
95-98 Acura TL
96-01 Acura TL
95-97 Honda Accord EX
95-97 Honda Accord LX
94-97 Honda Accord
98-02 Honda Accord
03-07 Honda Accord
03-05 Honda Civic Hybrid
92-95 Honda Civic
92-00 Honda Civic
01-05 Honda Civic
02-05 Honda Civic
93-97 Honda Civic del Sol
93-95 Honda Civic del Sol
97-01 Honda CR-V
07-08 Honda Fit Base
07-08 Honda Fit Sport
00-03 Honda Insight
95-97 Honda Odyssey
98-98 Honda Odyssey
96-97 Isuzu Oasis
Old Aug 27, 2013 | 02:57 PM
B_Swapped93's Avatar
Default Re: Integra Fuel Pump Info
80 lph seems extremely low for a type R considering the gsr of 94 has 119. Always thought it was 135lph itr/gsr ?
Old Aug 27, 2013 | 03:42 PM
TheRealTegger's Avatar
I don't know if it helps your database, but here's some factory information for some earlier Integras:
90-93 all but GS-R: 80 Lph (actually, the manual specifies the equivalent of 82.8 LPH as a minimum at 12V)
92-93 GS-R: 75 Lph
It's possible that Honda now omits pump-flow rates from their manuals because those rates can cause a lot of confusion when troubleshooting:
It looks to me as though injector-flow peaks at about 58 Lph for the set of 4, which is substantially less than even the lowest-capacity pump can deliver.
https://honda-tech.com/forums/showthread.php?p=39639753
Old Aug 27, 2013 | 06:52 PM
94eg!'s Avatar
#1 Super Guy
Loved
I thought so too, which is why I was originally considering a GSR pump for my Civic CX w/ B18C. But even still, the 80 lph pumps are proven to supply enough fuel for 200whp+ N/A builds.
The 94 OEM shop manual (page 3-7) specs the GSR pump flow at 131 lph (364ml/10sec) when new with a service limit of 36 lph (100ml/10sec). The funny thing is specs the B18B1's pump at 80 lph (222ml/10sec) with a service limit of 43 lph (120ml/10sec). Why the GSR's limit is lower I will never know. It may help to explain the difference between Honda's "new" spec and Denso's possible "nominal" spec of 119.
BTW: Thanks Tegger for the DA pump specs. To add to it, here's the Denso pump part numbers for them:
92-93 GSR - 951-0011
90-93 Non GSR - 951-0010
I didn't e-mail denso for their specs on these two pumps.
Old Mar 30, 2015 | 05:43 PM
raverx3m's Avatar
should probably add this for a complete info
B18C1 1996-1997 Acura Integra GSR DOHC 16V I4 VTEC 235
B18C1 1994-1995 Acura Integra GSR DOHC 16V I4 VTEC 235
B18B1 1994-1995 Acura Integra LS,RS DOHC 16V I4 235
B18A1 1992-1993 Acura Integra DOHC 16V I4 235
B16A3 1996-1997 Honda Del Sol Si VTEC DOHC 16V I4 VTEC 240
B16A3 1994-1995 Honda Del Sol Si VTEC DOHC 16V I4 VTEC 235
D16Y7 1996-1997 Honda Civic CX,DX,LX SOHC 16V I4 180
D16Y8 1996-1997 Honda Civic EX SOHC 16V I4 VTEC 240
D16Z6 1992-1995 Honda Civic EX,Si SOHC 16V I4 VTEC 235
D15B7 1992-1995 Honda Civic DX,LX SOHC 16V I4 235
D15B8 1992-1995 Honda Civic CX SOHC 8V I4 180
D15Z1 1992-1995 Honda Civic VX SOHC 16V I4 VTEC_E 235
D16A6 1988-1991 Honda Civic Si,CRX Si SOHC 16V I4 235
fuel pressure( all these are directly from service manuals for future reference):
98-01 b18b1 40-47psi
98-01 b18c1 47-54psi
98-01 b18c5 47-54psi
94-95 b18c1 48-55psi
93 b18a1 41-48psi
93 b17a1 48-56psi
crv 97-98 38-46psi
crv 99-00 40-47psi
96-00 Dseries 38-46psi
96-00 b16a2 40-47psi
92-95 civic 40-47psi
93-95 b16a3 40-47psi
it looked like fpr was different but now that looks like pump fpr and injectors can be different as well
Old Jan 9, 2016 | 08:20 PM
JayPNation44's Avatar
When you say the psi for the 92-95 civics is 40-47, is that what the factory setting are or what it should ideally be at to give the best results out of your fuel pump?
Old Jan 9, 2016 | 08:51 PM
raverx3m's Avatar
factory settings are what it should ideally be at for best results unless your motor is modified
Old Jan 13, 2016 | 06:50 PM
raverx3m's Avatar
fuel pressure regulators how to identify...
looking from front of the car.as you would when you working on it
b16a/b18b - bottom outlet straight down, top facing 11am mark towards plenum
earlier and some jdm b16: bottom facing 90degrees to the right and top straight up
b18c1 bottom straight down, top facing 90 degree to the right because gsr vacuum hose goes under the manifold
b18c5 bottom is about 30 degrees to the right , top facing 11am mark towards the plenum same as LS motor.
since Honda decided not to mark fuel pumps injectors or pressure regulators its pretty retarded.
there are still slight differences to identify them like the injector cap color and plug for different years.
because a combination of fuel pump injectors and FPR is needed in order to get correct fuel throughout the RPM so ecu can work properly.
I had wrong fuel pump and LS fpr in my gsr and had a massive lean spot in low/mid range at light throttle that went away with replacing both with the correct ones.
jdmfoglights
Dec 28, 2013 08:58 AM
XeiaieX
Sep 13, 2012 11:31 AM
denraweb
Feb 10, 2008 04:31 AM
ravenracer
May 26, 2007 04:47 AM
