1995 Honda Civic DX No start
Old Aug 27, 2013 | 03:52 AM
StedFast's Avatar
Default 1995 Honda Civic DX No start
Hello everyone, I'm sure it's been asked becuase I'm sure it's happened. I have a 1995 Honda Civic Dx that will try to turn over but won't. I'm not getting spark, but I have replaced the entire distributor, spark plugs and wires, alternator is good, battery is good (via checks and diagnosis). The main relay had cracked welding, so I re-welded and then just replaced with a new one, the ignition wiring harness is also new via a replacement. There is NO alarm/auto start hooked up. I have checked all the grounds and they are all clean and securely fastened. The CEL stays on and does not flash when I pull codes, I'm assuming this is a 0 code which is a bad ECU. Is there ANYTHING else that could be causing it to not turn over. And will the ECU if bad cause the fule pump not to prime? Thanks in advance!
Old Aug 27, 2013 | 04:03 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 1995 Honda Civic DX No start
Swap with a known working ECU.
chariseGH
20
Jun 15, 2015 06:19 PM
sean.rostami
May 6, 2012 06:33 AM
bigboi408
Oct 27, 2011 06:11 PM
hondadx92
Aug 12, 2009 07:04 PM
airbornedude
Engine Management and Tuning
Feb 3, 2009 08:03 PM
