FS: Mil-Spec B-series engine harness...
Old Aug 25, 2013 | 05:53 PM
Blown90hatcH's Avatar
Default FS: Mil-Spec B-series engine harness...
FS: Mil-Spec B-Series engine harness out of my 2000 Civic race car. All DR-25 Raychem heat shrink and adhesive lined heat shrink. Mil-Spec Teflon coating wiring. Most sensors identified with Raychem yellow labels with clear shrink. OEM, Deutsch, Bosch, GM, etc. connectors...all brand new, new OEM pins, etc. when I built it. The car had an OEM cluster in it so the harness comes with extra wires on the Deutsch connector for the dash indicators. I will provide a complete wiring pinout for all the sensors. Comes with OBD1 ecu connectors, but they can be changed out if needed. It has been wired for additional Bosch/AEM pressure sensors but also includes all of the following sensor plugs wired in:
OBD2 Alternator
OBD1 Distributor
Fan Switch
Starter Solenoid
Dash Water Temp
Engine Coolant Temp
VTEC Solenoid
VTEC Pressure Switch
Ground
Bosch MAP Sensor
Honda TPS
Turbo Compressor Pressure Bosch Sensor
Turbo Exhaust Back Pressure Bosch Sensor
Crank Case Pressure Bosch Sensor
VSS
Oil Pressure Bosch Sensor
Dash Oil Pressure Light
Intake Air Temp Honda
Injector Dynamics ID1000 Injectors
Fuel Pressure Bosch Sensor
OBD1 ECU
I can add a charge harness for an additional $40 if needed.
Price = $500
Old Aug 26, 2013 | 03:44 PM
Default Re: FS: Mil-Spec B-series engine harness...
Top
Old Aug 28, 2013 | 08:15 AM
Replied to your PMs.
Old Aug 29, 2013 | 08:03 AM
Bump
Old Aug 30, 2013 | 06:25 PM
Top
Old Aug 30, 2013 | 10:12 PM
Charlie Moua's Avatar
bump for jason
Old Sep 1, 2013 | 06:59 AM
Thanks buddy.
Old Sep 3, 2013 | 03:33 PM
Bump
Old Sep 4, 2013 | 03:54 PM
PMs returned. I can add/delete sensors if needed.
Old Sep 6, 2013 | 01:03 PM
Bump
Old Sep 7, 2013 | 06:59 AM
0487erasmo's Avatar
Good price! Bump
Blown90hatcH
Sep 9, 2013 03:56 PM
1989through2010
May 20, 2013 01:11 AM
TypeSLO
Sep 15, 2008 06:06 PM
ek9vboi2
Jun 24, 2005 07:44 PM
