FS: Mil-Spec B-Series Engine Harness...
Old Aug 25, 2013 | 05:51 PM
Blown90hatcH's Avatar
Default FS: Mil-Spec B-Series Engine Harness...
FS: Mil-Spec B-Series engine harness out of my 2000 Civic race car. All DR-25 Raychem heat shrink and adhesive lined heat shrink. Mil-Spec Teflon coating wiring. Most sensors identified with Raychem yellow labels with clear shrink. OEM, Deutsch, Bosch, GM, etc. connectors...all brand new, new OEM pins, etc. when I built it. The car had an OEM cluster in it so the harness comes with extra wires on the Deutsch connector for the dash indicators. I will provide a complete wiring pinout for all the sensors. Comes with OBD1 ecu connectors, but they can be changed out if needed. It has been wired for additional Bosch/AEM pressure sensors but also includes all of the following sensor plugs wired in:
OBD2 Alternator
OBD1 Distributor
Fan Switch
Starter Solenoid
Dash Water Temp
Engine Coolant Temp
VTEC Solenoid
VTEC Pressure Switch
Ground
Bosch MAP Sensor
Honda TPS
Turbo Compressor Pressure Bosch Sensor
Turbo Exhaust Back Pressure Bosch Sensor
Crank Case Pressure Bosch Sensor
VSS
Oil Pressure Bosch Sensor
Dash Oil Pressure Light
Intake Air Temp Honda
Injector Dynamics ID1000 Injectors
Fuel Pressure Bosch Sensor
OBD1 ECU
I can add a charge harness for an additional $40 if needed.
Price = $500
Old Aug 25, 2013 | 06:00 PM
hawaiieg6's Avatar
Default Re: FS: Mil-Spec B-Series Engine Harness...
That's not a mil spec harness mil spec is with the fire wall plug
Old Aug 25, 2013 | 06:10 PM
LOL! Wow.
It does not come with a Mil-Spec circular firewall disconnect plug. It does come with Mil-Spec wiring, shrink, etc. Mil-Spec isn't just the $60 circular man. Geesh.
Old Aug 25, 2013 | 07:57 PM
B2FiNiTY's Avatar
lol at hawaiieg6's comment
bump!
Old Aug 26, 2013 | 03:43 PM
Haha. Thanks man.
Old Aug 26, 2013 | 05:04 PM
Gunmetal_B20_Hatch's Avatar
reported for stupidity.
Old Aug 27, 2013 | 08:53 AM
Bump
Old Aug 27, 2013 | 02:31 PM
Clayton's Avatar
H-T Administrator
25 Year Member
**EFFECTIVE IMMEDIATELY**
From todays date (3/18) onward; anyone selling ANY product in the marketplace will be expected to post a picture of their item for sale with a sign included in the photo. On the sign, should be your username, date and the words Honda-Tech.com on it. It can be handwritten or printed on a piece of paper. No photoshopped signs will be accepted.
Old Aug 27, 2013 | 02:58 PM
Old Aug 28, 2013 | 08:14 AM
Bump
Old Aug 28, 2013 | 08:33 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Thanks
Old Aug 29, 2013 | 08:02 AM
Bump
Old Aug 29, 2013 | 06:06 PM
PMs replied
Old Aug 30, 2013 | 06:24 PM
Bump
Old Sep 1, 2013 | 06:59 AM
Sunday bump
Old Sep 2, 2013 | 05:23 AM
Moving up.
Old Sep 3, 2013 | 03:32 PM
Bump
Old Sep 4, 2013 | 03:54 PM
PMs returned. I can add/delete sensors if needed.
Old Sep 6, 2013 | 01:04 PM
Top
Old Sep 7, 2013 | 05:07 PM
Top
Old Sep 8, 2013 | 07:46 PM
Up
Old Sep 9, 2013 | 03:56 PM
Top
Blown90hatcH
Sep 7, 2013 06:59 AM
1989through2010
May 20, 2013 01:11 AM
TypeSLO
Sep 15, 2008 06:06 PM
ek9vboi2
Jun 24, 2005 07:44 PM
