GSR Cranks but doesn't start.
Old Aug 25, 2013 | 09:11 AM
TORTUGA's Avatar
Default GSR Cranks but doesn't start.
I recently did a GSR swap in my EK. I plugged up the harness and decided to run my P28 I had laying around. Last night when I tried starting it up the engine would only crank but wouldn't start. I waited for the fuel to circulate, that didn't help. I checked for spark and there's spark. Checked the fuel and there's fuel. The ECU is only throwing Code 21, which is the Vtec solenoid valve. Could that cause the engine not to turn on? What do you guys recommend me to do?
Old Aug 25, 2013 | 09:27 AM
B_Swapped93's Avatar
Default Re: GSR Cranks but doesn't start.
confirm firing order and mechanical timing. does it almost start like kind of stumble ?
Old Aug 25, 2013 | 10:20 AM
Former User's Avatar
Also, what color is spark?
And when you say there's fuel, are you saying that the fuel pump primes or that the injectors are spraying fuel?
Have you checked the mechanical timing?
Old Aug 25, 2013 | 12:18 PM
TORTUGA's Avatar
-Fuel pump is priming and injectors are all spraying fuel.
-Timing is good.
-It simply cranks but doesn't start, there's no stumble or anything.
Sprayed some starting fluid a few minutes ago but nothing.
When connected to the P28 ECU it only throws code 21 which is the vtec solenoid.
When connected to the OEM single cam ECU (d16y7) it only throws the IACV code.
Old Aug 25, 2013 | 01:27 PM
Old Aug 25, 2013 | 02:36 PM
teamXteg's Avatar
what about the grounds?
and what about the ecu? is it chipped? will a factory P28 run a DOHC motor?
Old Aug 25, 2013 | 05:38 PM
TORTUGA's Avatar
-Spark is white/blue
-I checked all the grounds and they all seem fine, also, the ecu is a chipped p28. I'm starting to think that it has to do with the wiring.
Old Aug 25, 2013 | 05:43 PM
Have you checked whether the plug and injector wires are installed in the wrong firing order?
If the engine is timed and has strong spark and the injectors spray fuel, then it's time to compression test the cylinders.
Old Aug 25, 2013 | 05:58 PM
TORTUGA's Avatar
-The spark plug wires are correctly put on. I still haven't checked the injector wiring though. Would I guide myself by the injector color wires?
-Another thing, do you believe that a mistake in the wire harness can cause the engine not to turn on?
Old Aug 25, 2013 | 06:00 PM
^Exactly
How do you know the plug wires are installed correctly?
Have you checked the CEL codes after cranking the engine for 30 seconds?
Obviously
Old Aug 25, 2013 | 06:08 PM
TORTUGA's Avatar
-Is there some type of diagram/picture that will show me in which order the wires are supposed to go wired? To be honest I don't feel 100% sure that they're in the correct order.
-Yes I have, it still throws code 21
Old Aug 25, 2013 | 06:10 PM
Injector wire firing order can be found here:
http://www.phearable.net/tech/wiring...schematics.gif
Do you know how the cylinders are ordered?
Old Aug 25, 2013 | 11:58 PM
Marvin1985's Avatar
Random idea. Pull dizzy and make sure cam key tabs arent broken
Old Aug 26, 2013 | 01:45 PM
TORTUGA's Avatar
I inspected the injector wiring at it all seemed okay.
I'm thinking about just pulling out the whole harness and re-doing/checking everything all over again.
Old Aug 26, 2013 | 02:03 PM
Plug wires?
Old Aug 26, 2013 | 03:00 PM
TORTUGA's Avatar
-Plug wires are good as well, checked the order in which they go.
I really hope it has something to do with the harness, maybe I made a mistake or something.
I used my stock single cam harness (D16Y7), and basically just did the following:
-Converted the IACV 3 plug into a 2 plug.
-Extended a few sensors.
-Ran the VTEC pressure switch/VTEC solenoid wiring.
I also took off my old single cam harness plugs that plug into the ECU because they were a tad bit damaged so just decided to change them out for some other single cam harness plugs, I basically just colored matched all the wires from the harness to the wires that the plugs had. One thing I did notice was that it had 2 identical looking brown wires and 2 identical looking yellow wires. Maybe I made a mistake somewhere around there.
Either way, I greatly appreciate your help.
Old Aug 26, 2013 | 03:03 PM
TORTUGA's Avatar
I also didn't extend the O2 sensor, knock sensor or IAB because someone told me that my P28 ECU wouldn't look for those sensors, is that true?
Old Aug 26, 2013 | 03:05 PM
Check for swapped sensor connectors and also compression test the cylinders.
Old Aug 26, 2013 | 03:17 PM
TORTUGA's Avatar
Okay I will do that and keep you updated
Old Aug 28, 2013 | 03:08 PM
TORTUGA's Avatar
It ended up being the timing, it was off by like 6 teeth.
Thanks a lot for your help, it's greatly appreciated.
wardawg1991
Oct 9, 2017 08:54 PM
Gary Harlan
Nov 19, 2016 04:15 PM
Domnificent
Jul 24, 2010 01:48 PM
blaxican05
Sep 29, 2006 08:23 PM
-[95cxhatch]-
Dec 16, 2003 05:18 PM
