f20b ecu help
Old Aug 25, 2013 | 08:47 AM
scotts99accord's Avatar
Default f20b ecu help
I got a 99 accord with a f20b swap with a obd2b to obd1 ecu jumper harness with a chipped obf1 ecu when I plug it in I have no fuel pump but when I plug in my cars stock ecu the fuel pump work is the a pin out difference?
Old Aug 25, 2013 | 10:30 PM
holmesnmanny's Avatar
Default Re: f20b ecu help
I'm not sure what an obf1 ecu is.
Be that as it may, you need to also use an obd1 distributor and you also need a distributor conversion kit from rywire.com that moves your existing cyp and ckp sensor wires from the crank over to the distributor. They sell a kit for this purpose. Or you can wire it yourself. If you wire it yourself be sure to use shielded wire.
Old Aug 26, 2013 | 05:27 AM
I ment obd1 and I already did a obd1 distributor conversion im trying to find out if with the obd1 jumper harness if I have to change any of the pin location being that im using my cars stock harness
I am using a chipped p72
Old Aug 26, 2013 | 08:02 AM
wincy's Avatar
I need help H23a OBD2A AT to MT
Old Aug 26, 2013 | 10:42 PM
ok so if you take the jumper harness out and run your existing ecu the car starts but if you put the obd2b to obd1 harness and the obd1 ecu the car doesn't start ?
Obviously when you use the obd1 ecu you need the obd1 distributor and you need to have the ckp and cyp wiring ran from the crank to the distributor so it's not just plug and play when doing that. I think that your distributor wiring is not correct. I would put the wiring back the way it originally was and pick up an obd2b to obd1 distributor conversion kit from rywire.com
Old Aug 26, 2013 | 10:56 PM
NZXTInerTia's Avatar
You could have easily found this out yourself. Both the distributor wiring diagrams OR a conversion harness by Rywire like holmes mentioned AND an ECU pinout for both your OEM ECM and your new ECM. Is it honestly that hard to even attempt to figure something out for yourself anymore? H-T makes me stupid..
Old Aug 27, 2013 | 12:03 PM
I did look for myself is it that hard for people not to be rude my question was more or less because the fuel pump didnt kick on wit the obd1 ecu but does with the stock one I have spark but thanx for the help tho
dfanatic86
Mar 5, 2014 05:23 AM
Project Phoenix
Jul 18, 2010 02:55 PM
88crxdxfastwhip
May 30, 2008 10:31 PM
fin781
Jan 19, 2007 09:16 PM
89sicivic
Feb 26, 2006 10:10 AM
