Running on 3 Cylinders
Old Aug 24, 2013 | 11:30 PM
SmaTTeRLegion's Avatar
Default Running on 3 Cylinders
JDM D15B SOHC Vtec, running rich, lose of power, motor shakes a lot, bad idle. Replaced Fuel Filter, Injectors/Fuel Rail. Started out throwing a CEL when you cruised at 40 and when you turned the car off it would go away when you turned it back on, now it comes on right when I turn the car on. First time I got the CEL code it was 43 (Fuel Systems). Haven't had a chance to check the new one (If it is new...). My buddy was telling me it sounds like it's not firing all 3 cylinders, what could possibly make it do that? I need a list of reasons so I can check it out tomorrow morning.
Spark Plugs, Spark Plug Wires what else?
Pretty sure it's Bosch spark plug wires and some platinum denso plugs, I have heard people say that denso run weird in hondas. Idk if it true or not but I plan on getting some NGK's here soon.
Old Aug 24, 2013 | 11:42 PM
teamXteg's Avatar
Default Re: Running on 3 Cylinders
i would test spark
check grounds
maybe a compression test
is it maybe out of time?
Old Aug 24, 2013 | 11:49 PM
One thing I did notice one time was 3 out of the 4 spark plugs were way more burnt up then one of them. I'm gonna do a compression test tomorrow, was going to do it tonight but didn't have time. I also thought it could be out of time but the thing is it didn't run like this when I first got it from the dude. Possible for it to get knocked out of time? I'll take a look at both of those tomorrow. I really think it might be the cheap denso spark plugs
Old Aug 24, 2013 | 11:56 PM
teamXteg's Avatar
it could of jumped time. that would make it run like crap.. but ya man give those a go and post ya results tomorrow and good luck! i know how nerve racking it can be! so good luck!
Old Aug 25, 2013 | 12:24 AM
Thanks, this has been driving me insane since I got the car a wile ago. Been running circles forever. Even raced the car on the car running like this.... So hopefully once I get it fixed I get to feel how much power I'm actually making.
Old Aug 25, 2013 | 12:52 AM
jbpnoman's Avatar
If one of your plugs isn't burning, that's a pretty good sign that you aren't getting spark in that cylinder. Get a spark tester tool from your local parts store (they're like, $10-$15). Follow the instructions on the packaging to see if you're getting bright white spark on all four wires. If you aren't, replace your cap, rotor, plugs, and wires. If you are, just replace your plugs and see what happens.
Old Aug 25, 2013 | 07:58 AM
Going out to work on the car right now, thanks for the replies guys.
jbpnoman, your from my favorite place in VA. Charlottesville is so pretty
Old Aug 25, 2013 | 08:13 AM
Fnix's Avatar
Check the timing it could have jumped!
Old Aug 25, 2013 | 08:38 AM
^ I'm on it right now, taking the cover off as we speak. Gotta love having the Ipad at your side wile you working on the car.
Old Aug 25, 2013 | 09:46 AM
B_Swapped93's Avatar
my guess is worn cap+rotor or bad wire(s). an ignition system component more then likely.
Old Aug 25, 2013 | 12:20 PM
Ok so the first cylinder isn't firing, pulled the spark plug wire out wile running and pulling the first one out didn't make it idle weird like taking the others out did. Anyway to check the cap and rotor before I buy a new one? If not I plan on buying new cap rotor and spark plugs.
Old Aug 25, 2013 | 01:15 PM
jbpnoman's Avatar
You can test the cap and rotor by process of elimination. Resistance test all of your wires with a voltmeter/ohmmeter. If they all show the same resistance, then do the spark plug test that I mentioned. If you aren't getting spark from one wire, but all four wires show the same resistance, it's the cap/rotor that's causing the problem.
And yes, Charlottesville is great, especially around this time of year. All the college girls are moving back into town
Old Aug 26, 2013 | 03:25 PM
Took the cap off, need a new cap and rotor. Has a bunch of build up on it and probably not sparking right. Just gotta wait for the pay check.... Damn it.
Old Aug 26, 2013 | 05:03 PM
teamXteg's Avatar
well good luck man! hope thats it and i hope it fixes it!
Old Aug 26, 2013 | 05:10 PM
Thanks for the help guys. Code 43 is the temp sensor and the cylinder missfire is the gas problem.
Old Sep 2, 2013 | 11:28 AM
She F***ING PURS! Got her up on 4 Cylinders and she sounds nasty with the new headers. Now all I need is spark plugs cause it starts to go back to what it was doing and pops when I get on it. Pretty sure it's just because my spark plugs are fowled. Thanks for the help guys.
bassamillion
Honda Civic (2001 - 2005)
Jun 20, 2018 05:55 AM
2ndGenREX
11
Jan 13, 2007 01:50 PM
smallttocs
May 25, 2004 08:39 PM
SSBlueDC2
Feb 7, 2003 07:45 PM
AutoboTxEK
Apr 3, 2002 09:49 AM
