oil pressure switch question
Hey I rebuilt my b18. Shortly before getting it rebuilt, the oil light was turning on but not fully, just a little bit. I replaced the oil pump and everything works fine, but 3 works after, the oil light is on again in the same way. I can see it on only at night. Do you think is the oil pressure switch that needs to be replaced or the oil pump failed? I must say that my car is at 750 rpm when idling and it doesn't shake
No, it was used. We checked it and it was ok. I've read that if the oil is so thin, when the engine warmps up, the oil becomes even thinner and that would make the pressure go lower, because the light in my cluster is barely noticeable. Is that true? Idk how much a new oil pump costs
The pressure switch supplies a ground, [when pressure is up] to the oil pressure warning light, the ign. supplies the power to the bulb, to test switch, unplug it, start engine, if light is out the switch is the problem, replace it, if the light is still on, the problem is wiring, the lead running from the switch to the oil light is shorting out, [minor short], if the light is bright when you turn on the ign. switch the oil light circuit is good, [other then a possible minor short]. 94
