Washer pump working but no spray? DA9 teg
Old Aug 24, 2013 | 03:05 PM
TheOnlyBobaFett's Avatar
Icon2 Washer pump working but no spray? DA9 teg
So as I try to get my teg road legal I find that my wipers work but no washer fluid coming out of the nozzles(Front and rear nozzle). I tried to take a small needle and clean them but still no fluid. Is there anything else I can try? The pump comes on and wipers work just no fluid. Any help would be much appreciated
Old Aug 24, 2013 | 06:08 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Washer pump working but no spray? DA9 teg
Trace the hoses and see if there is a disconnect somewhere
Old Aug 24, 2013 | 06:15 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Check if there is a clog
Old Aug 24, 2013 | 07:33 PM
HellaStockEJ6's Avatar
Take your driver side fender off and your bumper if you wish, it will allow you full access to the washer fluid container as well as the hoses
Old Aug 25, 2013 | 08:52 AM
Lord Helmet's Avatar
Trace the washer line for pinched hoses near the hood hinge mounts. If they're pinched no water will go through but your wash pump will still work, etc...
Old Aug 26, 2013 | 04:08 PM
So I traced the lines they are all set can it be that the pump comes on but doesn't move/pump any liquid?
Old Aug 26, 2013 | 04:12 PM
Shit Posts: 15
10 Year Member
The pump may be clogged.
Do you see any water in the lines at all?
If so, the jets may be clogged.
If not, the pumps are bad or clogged.
Run some wd40 trough the pumps and jet b
Old Aug 26, 2013 | 05:00 PM
When you say pumps do you mean there is two? Like in some car they have there own reservoir and pump. The lines are bone dry and the pump makes noise but seems like it isn't actually pumping any liquid at all. Should I just buy the 20$ pump at the store (NAPA) and try that?
Old Aug 26, 2013 | 09:42 PM
B_Swapped93's Avatar
pump's as in "pump is". But for 20$ go to a junk yard and grab a whole tank or 2 for that price i'd bet the pump is just old and something broke internally.
moonchies
Aug 11, 2017 03:03 PM
onereving7
Acura TSX
Apr 11, 2009 12:38 PM
wdissident
Feb 9, 2009 10:53 PM
J-who
Feb 5, 2007 01:18 PM
michaelpr
Aug 4, 2001 11:24 PM
