Windshield Washer Pump
Old Aug 4, 2001 | 03:34 PM
michaelpr's Avatar
New User
Default Windshield Washer Pump
I have an 1989 Integra LS. The windshield washer fluid does not squirt out. I want to check the pump to see if it is receiving voltage or not. However, I cannot locate it. My manual does not talk about it. Does anyone know when it is located exactly? I have been looking and looking for it. Also, anything else I should check, or any hints on this matter?
Thanks in advance!
Old Aug 4, 2001 | 07:55 PM
G3-GSR's Avatar
New User
Default Re: Windshield Washer Pump (michaelpr)
Before you do the voltage check, check the lines first. Can you hear the pump working? If so, you prolly got a clogged fluid line somewhere, which is easy to fix.
Old Aug 4, 2001 | 11:24 PM
BreakStuff's Avatar
New User
Default Re: Windshield Washer Pump (G3-GSR)
Your pump is located on the bottom of the washer fluid bottle..
listen for the pump first to see if it's actually working..
u118224
Jul 4, 2014 06:41 AM
TheOnlyBobaFett
Aug 26, 2013 09:42 PM
wdissident
Feb 9, 2009 10:53 PM
hondacivicgirlfriend
Nov 29, 2005 04:47 AM
zijiejijeijrkjk
Mar 15, 2002 05:28 AM
