car wont start
Old Aug 24, 2013 | 01:19 PM
lxdriver's Avatar
Default car wont start
I was driving fine and stopped at the store for quick drink. Went back outside to start the car and it just simply wouldnt. Ended up having to push-start it and driving home. Once there I turned it off and would not start again. I hear a click if I try to start it but it just wont. I hear the fuel pump kick in, and the car has power it just wont start. I'm thinking the starter maybe? Or could it be something else? Thanks guys and gals
Old Aug 24, 2013 | 02:52 PM
HOMEMADEPOWER's Avatar
Default Re: car wont start
Take out the starter and take it apart and clean the +/- terminals with a wire brush. I had the same problem after cleaning the starter I had no problems since. Instructions are in FAQ.
Old Aug 24, 2013 | 03:52 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
If it pop-started it's most likely the starter.
Old Aug 24, 2013 | 04:48 PM
Former User's Avatar
Is the click coming from the starter solenoid or the starter cut relay?
Manual transmission? Have you checked whether rubber stopper at the top of the clutch pedal fell out?
Old Aug 24, 2013 | 05:02 PM
lxdriver's Avatar
The click is coming from the dash when I open the key, but nothing once I try to start it even after pushing in the clutch. All wires were connected properly before I even touched it to remove it
Old Aug 24, 2013 | 05:43 PM
Old Aug 24, 2013 | 10:30 PM
teamXteg's Avatar
is there a chance that the battery has just took a dump?
Old Aug 25, 2013 | 02:22 PM
lxdriver's Avatar
Nah battery and starter are brand new and my girl is back to normal, its just that weird swirling noise every time I start it
Old Aug 25, 2013 | 04:29 PM
jzuri61's Avatar
The same thing happened to me. All i had to do was clean the terminals with a wire brush. They weren't making full contact.
Old Aug 25, 2013 | 05:51 PM
Contribute to the community by sharing how you fixed the problem.
Old Aug 25, 2013 | 07:30 PM
lxdriver's Avatar
Normal as in the car starts again, but now the swirling sound is there so idk whats up with that
Old Aug 25, 2013 | 07:31 PM
^The fix?
JPerkMr954
Jun 9, 2013 08:51 PM
sevenfc
11
Sep 25, 2009 07:26 PM
JDM_d15b_eg8
Oct 11, 2007 03:55 PM
civicstar
Jun 8, 2007 08:26 PM
