Transmission & Drivetrain Gearboxes, Differentials, Clutches
Are D diff and spider gears same as B?
Old Aug 23, 2013 | 07:34 AM
si90rex's Avatar
Default Are D diff and spider gears same as B?
I have a friend I'm going some trans work for. He is in need of a B16/ls diff, i happen to have a b16 diff that customer blow apart at the track because he didn't preload. My question is will the spider gears and differential gears swap out of a d series diff to a b series? these are both open diffs and both hydro trans. Im just trying to come up with a cheap solution.
thanks for any help
Old Aug 23, 2013 | 10:44 AM
pgpbubble's Avatar
Default Re: Are D diff and spider gears same as B?
No they won't. I know the axle spline count is different. As is probably the diameter/size of the side gear.
Old Aug 25, 2013 | 05:15 PM
si90rex's Avatar
dang, i forgot about the spline count... thanks!
tysonzane
Aug 22, 2020 03:58 AM
hrowell88
Feb 1, 2015 06:07 PM
93accordxl
Jan 20, 2011 12:52 PM
marcusgnf
Jan 30, 2009 10:33 PM
eg9matt
Jul 4, 2008 02:26 PM
