Help mounting clutch cable through firewall for auto to manual 88-91 hatch!
Old Aug 23, 2013 | 03:10 AM
chirp the 1-2's Avatar
Default Help mounting clutch cable through firewall for auto to manual 88-91 hatch!
In the process of doing my auto to manual b18a on my 89 civic hatch dx , I am trying to figure out the best/proper way to locate the clutch cable where it goes through the firewall. I saw a thread on here where somebody cut a mt firewall so they had the proper clutch cable tunnel. So my question is how did YOU do it, any problems or issues? Ive heard of people having problems when done the wrong way. I see the integra cable has two little O-rings and a recess around it where it goes through the wall, is this for a retainer clip? Please help and give your personal experience. Thanks
Old Aug 23, 2013 | 04:01 AM
jdmjunkieXL's Avatar
Default Re: Help mounting clutch cable through firewall for auto to manual 88-91 hatch!
Look at ur firewall harder just stare at it....theres a hole there already
Old Aug 23, 2013 | 04:28 AM
Ya, no there's not
Old Aug 23, 2013 | 10:16 AM
ethos909's Avatar
Mine didnt have one, i just punched a hole in it with a balljoint tool and a hammer lol, never had a problem
Old Aug 23, 2013 | 10:17 AM
ethos909's Avatar
But yea the other guy above me is right, some efs already have a hole, the homie has an automatic one and his has the hole, just plugged up
Old Aug 23, 2013 | 10:32 AM
Yea mine had a plug
Old Aug 24, 2013 | 05:11 AM
heres my firewall, as you can see no hole behind the pedal where the linkage would hook up
Old Aug 24, 2013 | 05:16 AM
Heres what I saw somebody else do , I see small differences in the integra cable and the civic cable. I just want to know what really holds it in, is there a retaining clip or does the tunnel just kinda locate it and hold it in place and the tension keeps it from moving?
Old Aug 24, 2013 | 08:33 AM
jonGSR's Avatar
All you need to do is drill the hole in the correct spot. The tension will keep it in place. I did this about 2 months ago on an auto 88 dx hatch that didn't have the hole.
Old Apr 11, 2021 | 06:38 AM
bhawk's Avatar
Originally Posted by chirp the 1-2
Ya, no there's not
it might be welded shut or has one of the black plugs to fill it. I'm currently looking for the same hole. went about a year after removing everything so I'm a little unsure what I'm looking at.
is this the correct hole? beside the brake booster?
Old Apr 11, 2021 | 08:54 AM
Marcos Barrios's Avatar
yes
thats the hole
when i did my 5 speed swap
i had a rubber plug to remove
my car is a 1990 sedan
i know that some cars you just have to drill threw
because what you see in the picture is two panels up against each other
the panel up front had the hole cut out for a clutch cable
but the inside one did not
this was a mistake at the factory but a mistake that didnt need fixing because the automatic cars were never
ment to be 5 speed swapped
untill we came in hehe ^_-
Old Apr 11, 2021 | 11:35 PM
ethos909's Avatar
Originally Posted by Marcos Barrios
yes
thats the hole
dawg it’s been about 8 years. I’m pretty sure he’s figured it out by now smh 🤦‍♂️
Old Apr 14, 2021 | 04:07 PM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
This is from a few days ago.
Old Apr 17, 2021 | 02:07 AM
bhawk's Avatar
oh. well I guess I wasnt paying attention. but we here now arent we ? lol
Old May 29, 2021 | 05:56 AM
EFB18C1's Avatar
So I was on here looking for a solution. Will a 1990-1993 Acura Integra clutch cable fit and function like it should on a 1990 Honda Civic Hatch with a gsr swap
soon2befast
May 29, 2021 05:53 AM
be8teensee1
May 17, 2009 09:18 PM
texaszcrx
Aug 10, 2008 09:20 AM
quik1
Dec 23, 2005 10:22 PM
hb_guy
Oct 31, 2005 03:43 AM
