car dies right after start up
Old Aug 22, 2013 | 10:57 PM
boostfever's Avatar
Default car dies right after start up
Just go done rebuilding my motor and now the motor will not stay on in neutral unless I keep my foot on the gas pedal. Once i let go the gas pedal it will idle down and shut off the motor. Wierd thing is if I u nplug any vacuum line the motor will stay on during neutral around 700 rpm. Any one know what might cause this?
Old Aug 23, 2013 | 07:33 AM
averyvm's Avatar
Default Re: car dies right after start up
Do you have fresh plugs with fresh plug wires and a nice ignition coil?
Old Aug 23, 2013 | 02:41 PM
boostfever's Avatar
Yes, everything is brand new with the build
Old Aug 24, 2013 | 12:10 AM
hell0curry's Avatar
Make sure you have good grounds. I just swapped ny motor earlier this week too, had the same problem, but as i was going to test my dizzy, i found out thaf the ECU ground on the engine harness wasnt properly grounded.
That ground is located on the back of te block on the thermostat housing nesr thh water pipe.
Old Aug 24, 2013 | 09:48 AM
boostfever's Avatar
all grounds are connected
ekayhatch
Jan 29, 2011 05:14 PM
bmwe362006
Feb 5, 2009 06:46 PM
MasterFunk
Aug 28, 2008 06:38 PM
mykem
Dec 1, 2003 05:54 PM
Allstar
Apr 8, 2002 11:52 PM
