GSR integra major oil leak *PICS*
i have a 1997 integra gs-r.
I am convinced that the leak is coming from this aftermarket oil cooler
that the previous owner installed. but i am definitely not 100% sure
it only leaks after i start the car up, and when it leaks, it comes out fast.
this just happened out of no where, and im really trying to figure out the issue.
any advice would help. Here are some photos
I can pull that blue thing off and just run the filter to the block? I thought the gsr has a stock oil cooler that goes to the block, and the filter connects to that
looks like you have a couple sensors hooked up to "that blue thing" but yeah just pull it off and take a look at the o-ring on it, maybe buy a better quality sandwich plate.
had this exact problem once.gasket on the sandwich adapter has collapsed with the heat of motor.
looks like they changed the oil filter screw to the type without the cooler so if you remove the sandwich adapter you should be able to screw your oil filter to that and it would stop leaking.
It looks like you have an oil temp & oil pressure guage hooked up now. I would run the filter by itself and leave those disconnected until you can get a better sandwich plate adapter. This looks like a generic chinese ebay one.
reference:
