Post your pre-race checklist
The CRX is almost ready for it's first trip to the 1320. And I need to comeup with a checklist to go through each time it goes to the track. What are your guys checklists?
I'm mostly interested in just the people with track only trailer queens. Not street car guys that sometimes go to the strip..
check coolant, oil levels. check timing again before a pass, as well as to see if fuel pressure is where it was at one point. check your slick pressure after you pull if off the trailer as well as in the staging lanes again. 2nd gear burnout to heat them up.
Helmet, gas, check oil, coolant, tire pressure.
Also make sure that lug nuts are tight, and I have at least a pair of spare axles and tools to change them out with.
well i don't have a trailor queen, but it is on long trips. But for the local events: sunscreen, helmet, jacket, oil, coolant, fuel, tools, and a ride home if i break something.
greg
That was going to be my next question..
About spares...
Axles? I can definitely see that. I can see having a spare headgasket as well, and have actually thought about a tranny. Spark plugs are easy enough to have spares. Timing belt? Dizzy?
About spares...
Howabout this:
Post anything that has ever needed to be replaced (in a Honda) at the racetrack, and the type of racing you were participating in when you had the failure.
I'll start:
Wheel studs (autox, sheered off when putting on the race wheels)
We're trying to get a list of spares that we'll need to be using.
I'll start:
ID_ten_T
Mar 29, 2004 04:32 PM
l
Aug 22, 2002 04:01 PM
Steppin Razor
Sep 21, 2001 02:42 PM
