Valve springs for itr cams
I purchased supertech valve springs for use on my b16 with CTR cams. I read in some old topics that people say these were good to use with CTR's just recently i found the seat pressure for CTR's to be 50 lbs i believe. Would it be good to use these with the 70 lbs seat pressure. I always went and got titanium retainers but just read they wear in 20000k miles? Am i looking at excessive wear on my cams and rockers using these stiff springs?
Currently running oem 1st gen b16 springs and retainers.
Outer Spring -- 29.05mm OD -- 21.85mm ID
Inner Spring -- 20.50mm OD -- 15.50mm ID
70 lbs seat pressure -- 70 lbs @ 33.50mm
14.00mm Max Net Lift
19.50mm Coil Bind
10.00 lbs/mm Rate
19.50mm Coil Bind
10.00 lbs/mm Rate
I've never seen oem cams wear. I know allot of boosted guys will run stiffer springs with oem cams as well. Just be sure to set lash to correct settings. Your retainers will be fine - snap fit design
Yes ti retainers will wear much faster than oem or stainless. For a race car that gets torn down every season ti retainers and valves daily driver OEM or stainless. You will be fine on the seat pressure with OEM cams its the regrinds that tend to fail. More seat pressure will just let u rev higher
Ti retainers wear when they are not the snap-fit design.^
OP - if you only plan on revving stock rpm and you can get your money back, I would return them. Unless you plan on upgrading your cams later down the road.
im using itr springs with itr cams in my lsvtec. i think they are pretty reliable up to 8700 and i have seen them float valves at 9000.
if i were you, i would return the retainers and pick up some of the 02-03 rsx retainers they are cost effective and will work fine. as for the itr valvesprings id put them in a box on a shelf. never know when you or a friend could use a set
i know of 2 local cars that had piston to valve contact running itr springs up in the 9000 rpm range.
it should be noted that i am talking about the dual springs only, not the retainers. iirc the b series vtec oem retainers dont really like much more than 8400-8500 rpm.
rocket that chart is worth a thousand words.
rwautomotive
May 19, 2016 10:51 PM
TB123
Jun 16, 2010 04:25 PM
screaminvtec
13
Jul 23, 2005 10:50 AM
chechin
May 31, 2005 07:53 AM
