Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Radiator/ Condenser Fans
Old Aug 22, 2013 | 06:39 AM
kvnrpp's Avatar
Default Radiator/ Condenser Fans
I recently purchased a 2013 Honda Civic. However, I have one question about the AC. With my parents Honda Accord and Element, whenever you turn the key to IG2 (just before you start the engine) with the the AC on, you can hear the condenser fan before the engine is even started. On my Civic, this appears to not be the case.
The fan does come on and cycle normally with the clutch once the engine is started. Perhaps its just me, but is this normal? Thank you so much for your help!
Old Aug 22, 2013 | 01:41 PM
kvnrpp's Avatar
Default Re: Radiator/ Condenser Fans
I contacted the dealership in which I purchased the vehicle. Here's the explanation from the head mechanic:
"That was a good question. I don't know why it has changed but this is normal
for your vehicle. I checked a new Civic on the lot and found it to be the
same as your vehicle. I assume it was changed to lessen the draw on the
battery but don't know for sure if that is why or not but it is normal."
Old Aug 23, 2013 | 05:06 AM
vladd's Avatar
The fans come on at a certain temperature. Just because the car is running doesn't mean that the fans need to.
Old Aug 23, 2013 | 06:37 AM
kvnrpp's Avatar
Understood. I was just confused as it seems Honda has changed things. As with my parent's cars, the condenser and radiator fans would come on before the engine was even started with the AC on. It seems now that with my Civic, let alone other 2013's, not to be the case anymore.
Noob@Cars
Mar 1, 2016 05:53 PM
chicago00
Mar 18, 2015 05:34 AM
DannyBoy310
Sep 19, 2012 02:29 PM
nirajorel
Aug 28, 2012 12:30 PM
jazz215
Aug 23, 2003 10:48 PM
