Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
GoPower Cam install on R18 and no run!
Old Aug 20, 2013 | 11:29 AM
Alexmn2's Avatar
Default GoPower Cam install on R18 and no run!
Ok so I just installed the GoPower Camshaft for the R18 and its running rich as hell (10.14) and it sputters out and dies after 30 seconds. I was told that the vacuum length is super high for where it is. (Idk what that means but I guess its bad) doesnt stay running for long. I'm guessing its a vacuum leak but I havent found anything yet. IDEAS???
Old Aug 20, 2013 | 11:35 AM
doood's Avatar
been there done that
Default Re: GoPower Cam install on R18 and no run!
is your timing correct?
Old Aug 20, 2013 | 11:37 AM
Alexmn2's Avatar
no its probably off but its been looked at by Dr. Rulo from e-tunez.com and he couldnt do anything about the sputters and stalling
Old Aug 20, 2013 | 11:43 AM
doood's Avatar
if mechanical timing is off it wont run correctly until you fix it
Old Aug 20, 2013 | 11:51 AM
Alexmn2's Avatar
isnt the r18 electronically controlled timing? i lined up TDC when I tore it apart and lined it up again on rebuild.
Old Sep 3, 2013 | 02:42 PM
xile6's Avatar
Youknow you need a tune to run a new cam.
Old Sep 3, 2013 | 10:45 PM
crazed_8thgen's Avatar
http://www.8thcivic.com/forums/go-po...iscussion.html
Idk if that helps or not
Old Sep 9, 2013 | 01:09 PM
Alexmn2's Avatar
Originally Posted by crazed_8thgen
Oh I know. My car is currently sitting at National Speed Performance in Wilmington, NC for a tune. Theres more wrong than just a tune needed. my AF sensor is reading backwards and my ECU is overcompensating for the incorrect reading.
9hatch2
Nov 17, 2005 12:18 PM
.Kevin.
20
Sep 9, 2005 01:59 PM
ludewithanh22
Oct 1, 2004 09:20 AM
Soccerking3000
24
May 14, 2004 08:30 AM
