VSA problem
Hey, I'm brand new here, but I have an '07 Civic Si Sedan and have been having some VSA issues. The VSA light and exclamation point come on after I've been driving for about 10-20 minutes. When I shut the car off and restart it, they are gone, but come back on again after another 10-20 min. Any ideas what could be causing this or how I can get this resolved? Also, will continuing to drive with VSA issues create future problems? Thanks.
the "exclamation point" is the tpms (tire pressure monitoring system)
take it to a good tire shop and ask them if they can please reset/check if all your tpms sensors are working correctly.
the vsa means that one of the wheels is not sending a signal to your ecu, I think the signal is linked with the abs light, but you didn't mention the abs light coming on; jack all side of the car up(at once) and clean the abs teeth wheel and the sensor above the teeth wheel.
calcnerd
Sep 24, 2002 08:07 PM
