Terified to start my car
Old Aug 19, 2013 | 01:16 PM
99teggsr's Avatar
Default Terified to start my car
Super long story, but essentially I cleaned my throttle body because the TB butterfly would not return to closed. this is after spending hours adjusting throttle cable tension , etc. So I sprayed carb cleaner in the TB and flooded it.
Tried starting, nothing, nothing.
Eventually realised Ive got no spark, rode my bike 26 miles today to get a new dizzy, Ive now got spark. Changed oil because so much gas had mixed with it, and now the new oil also smells of gas, hoping I can acutally drive yto get new oil tonight.
So im terrified of trying to get this thing started again because last time I did I burnt out my dizzy, and gasolined the oil.
What can I do the ensure I dont damage my new dizzy , or make my new oil worse ???
see this if you want the long version :
http://crxcommunity.com/viewtopic.ph...775602#p775602
Old Aug 19, 2013 | 01:31 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Terified to start my car
I'm interested in responses because I'm not sure how you can prevent damage to the distributor or make your new oil worse. What makes you think you have something to worry about?
I would've already turned the key personally...
Old Aug 19, 2013 | 01:47 PM
99teggsr's Avatar
Im worried that whatever happened before to fry my distributer is going to happen again and its not going to start and im going to be back where I was three days ago with a flooded engine , bad oil, and a broken dizzy.
Maybe im paranoid.
nope, not paranoid. Just tried cranking it, nothing except a slight jump in rpm. Not a cough, not a sputter , nothing...
Ive got fuel, spark, and car was running near perfect before flood.
$100 to the first person to come to sarasota and start my car
Old Aug 19, 2013 | 02:28 PM
99teggsr's Avatar
NO CEL, grounds good ( I think, should I check each one with meter ?? ) , have spark on all four wires, fuel ....
WTF is going on guys
Old Aug 19, 2013 | 04:48 PM
24TEN's Avatar
PHANTOM MENACE
Firing order is correct?
Old Aug 19, 2013 | 05:38 PM
sstupid's Avatar
10 Year Member
180 degrees out.
Old Aug 19, 2013 | 06:28 PM
lsdisk0's Avatar
3 4
1 2 <<< plug wire order on dizzy
looking from the top of the engine
4 3 2 1 for which cylinder is which
Old Aug 20, 2013 | 12:07 AM
EFmine's Avatar
make sure youre getting spark at the plug and make sure the plugs arent fowled out due to the excess gas
Old Aug 20, 2013 | 04:00 AM
Tim512001's Avatar
Maybe I just haven't heard of the problem before but, gas in the oil?? That can happen by simply flooding the engine? Or is another problem that's been overlooked?
Posted from Honda-tech.com App for Android
Old Aug 20, 2013 | 06:32 AM
99teggsr's Avatar
Plug order is correct, new dizzy installed correctly. Gas is in the oil because of flooding the engine, the excess gas in the cylinders soaks down past the piston rings and accumulates in oil. Cause oil to lose its viscosity , in turn making you lose compression.
Ive got Spark at all four plug wires, they are on correct, rotor turns when cranked (know timing belt isnt broken)
after I initially flooded it I did try jumping the starter so I could crank and test for spark, well I think I did that wrong because I had a nice size spark, I think thats what fried the dizzy. Maybe took out the Ignition switch also with it ??? could an ignition switch that turns the car on, and cranks it, still be bad ????
Would like to test it but cant find a manual for 89 crx dx. only ones I have are for JDM CRX or ef sedan, and the colors and such dont match up.
Pulled ECU last night, looks brand new inside, no burn marks or anything. When I turn car "ON" I hear pump prime, and as its priming I get the CEL until done priming then it clicks off. So I think my ECU is still good.
checked all under dash fuses with multimeter, all good. checking engine compartment fuses now with meter.
Really at a loss here, ready to take a loss and sell this thing. Anyone around Sarasota that wants to make $100 ?? come help me for 8 hours for $100. You dont have to be the best mechanic in the world but I would want you atleast to be as experienced as I am or more. 941-323-3505
jspinelli8
Mar 29, 2018 04:34 PM
danny_ha
47
Apr 9, 2012 05:26 PM
Afireinside2285
Oct 5, 2010 03:49 PM
GSE980
Jun 1, 2007 08:49 AM
lswift
Aug 3, 2004 08:04 PM
