Neutral safety switch on 96 Honda accord
It's a 90% chance my car is having issues because of the neutral safety switch. Where exactly is it located my mechanic seems kind of confused so I want to make sure he's working on the correct area. He says its located under the center console where I have my gears. But I also read it could be by one if the tires. It's a EX 4 cylinder.
Should be #2 which is located at the gear select lever.
http://www.hondaautomotiveparts.com/...5=SELECT+LEVER
It could be intermittent. If there was a short in the switch and or the wires and they lost contact intermittently. A loose wire connector could do that as well.
Looks like I have the same problem. I was able to start it to get it home by taking the meter probe(as a wire) from 12v battery to the solenoid terminal (I believe "S" terminal), the smaller, of the two anyway. Got Korki out of a bad neighborhood
. Troubleshooting time.
. Troubleshooting time.Thread
