crv suspension on an integra
Old Aug 19, 2013 | 10:51 AM
Allday Dabbin's Avatar
Default crv suspension on an integra
So i built a monster stereo and now the rear end is sagging bad. my question is this. If i buy the integra type r rear lower control arms will the rear struts and springs off a crv fit on my integra to help compensate the added weight from the stereo? if so will i need to do anything else to make it work.
Old Aug 19, 2013 | 02:55 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
Default Re: crv suspension on an integra
so you want to put truck springs on a passenger car?
Old Aug 19, 2013 | 03:31 PM
B_Swapped93's Avatar
pics of stereo (subs) ? I find this hard to believe....
Old Aug 19, 2013 | 05:23 PM
and yes i want truck suspension on a passenger car. i mean people do it vice versa to lower the crv.
subs are dc audio level 4 which weigh 40 ish pounds each. the extra battery itself is 100 pounds and i need 2.
Old Aug 19, 2013 | 06:04 PM
ohh.....
they should fit with itr LCA's or you could get coils(coil overs) and play around with those. but your idea should work and be relatively cheap.
Old Aug 19, 2013 | 07:04 PM
oh my
i would be concern about the hatch glass shattering
Old Aug 19, 2013 | 07:43 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Wow. Quite the system. Stock suspension or aftermarket? Have you tried just finding stiffer springs?
Old Aug 19, 2013 | 08:39 PM
stock suspension right now. i have checked about stiffer springs but a bit above my budget right. that said that is why i have been researching alternative fixes
KDH22
Jun 5, 2015 06:11 PM
felare22
Dec 22, 2007 05:38 AM
B18 Piston
Suspension & Brakes
11
Oct 8, 2007 07:18 AM
87integraRS
May 8, 2004 06:29 PM
crxguy05si
Apr 18, 2002 04:10 AM
